[solved] ubuntu install - not upgrading
Giuliano69
Post by Giuliano69 » Thu Mar 11, 2021 2:52 pm
Ubuntu 20.04.02 - 64 bit
Download qcad-3.26.1-pro-linux-x86_64.run; made it executable, run.
Under ~/opt/ , there is NO new qcad directory (3.26.1)
Tryed to reboot ... same result.
Which is the correct install procedure for Qcad Update under ubuntu ?
Re: ubuntu install - not upgrading
Post by andrew » Thu Mar 11, 2021 2:58 pm
What is the output on the terminal when running qcad-3.26.1-pro-linux-x86_64.run? Are there any errors? Could it be that the download was not yet complete or was interrupted?
Perhaps, you can check the MD5 checksum for this file:
c7692c0cbf758bea0e8f5010f1bd0c95
Otherwise, the file size should be: 163755886 Bytes
Post by andrew » Thu Mar 11, 2021 2:59 pm
For detailed installation instructions, please refer to:
https://www.qcad.org/en/component/conte ... tion-linux
Giuliano69
Post by Giuliano69 » Thu Mar 11, 2021 3:38 pm
nice shot Andrew !!
running the installer FROM the command-line everything works....
I really cannot catch what was the problem....
Thanks a lot !
Giuliano
Post by andrew » Thu Mar 11, 2021 3:46 pm
Excellent, thanks for letting us know.
