QCAD 2 installation in Ubuntu 11.1 Problem
Posted: Sat Oct 22, 2011 12:27 pm
by vkadal
I have QCAD 2.2.2.0-1-prof-linux.x86. This was working fine in my Ubuntu 10.04. Now I have installed ubuntu 11.1 where it is not running. It 10.04, there is no installation issues, I just clicked qcad and the application is launched. Now it is not so. Can anyone help?
Posted: Wed Oct 26, 2011 2:09 pm
I will try to install Ubuntu 11.1 to reproduce the problem.
QCad Installation Problem
Posted: Wed Oct 26, 2011 2:13 pm
by vkadal
andrew wrote:I will try to install Ubuntu 11.1 to reproduce the problem.
Great :D
Posted: Wed Oct 26, 2011 2:32 pm
Seems to work just fine here with a standard installation of Ubuntu 11.1.
Please try to launch it from a Terminal, to see if there are any error messages or warnings:
- launch Terminal
- change to directory where you have installed QCAD
- launch QCAD with ./qcad
Also: did you install Ubuntu 32bit or 64bit? In the latter case, you will have to install package 'ia32-libs'.
Posted: Wed Oct 26, 2011 3:35 pm
by vkadal
amazingly fast response! Let me try. I am new to Ubuntu 11.1. I have not seen the terminal window. I will try to find and come back to you. In the mean while I have saved the QCad in the desktop. Kindly suggest me better place to store it.
Posted: Wed Oct 26, 2011 3:49 pm
by vkadal
The issue is resolved. I have not installed the application. After installing, it works fine. How to create a launcher in the desktop, instead of going to terminal window and opening it? This is not very iportant. Thanks a lot for the help. :D
Re: QCAD 2 installation in Ubuntu 11.1 Problem
Posted: Wed Nov 02, 2011 8:21 pm
by RayArdia
vkadal wrote:I have QCAD 2.2.2.0-1-prof-linux.x86. This was working fine in my Ubuntu 10.04. Now I have installed ubuntu 11.1 where it is not running. It 10.04, there is no installation issues, I just clicked qcad and the application is launched. Now it is not so. Can anyone help?
Exactly the same problem. My qcad 2.2.2.0-1 prof file still sits in my home folder. Previously (10.04) I had to click there, then in qcad folder, on a blue diamond-shaped icon.
From Terminal:-
[email protected]:~$ cd qcad-2.2.2.0-1-prof.linux.x86
[email protected]:~/qcad-2.2.2.0-1-prof.linux.x86$ ls
bin doors fonts misc patterns scripts
doc examples library partlibrary-2.1.2.8-1 qm templates
...... just in case it helps!
Posted: Wed Nov 02, 2011 8:34 pm
by RayArdia
Tried ./qcad and ./qcad-2.2.2.0-1-prof.linux.x86
From Terminal
[email protected]:~$ ./qcad
bash: ./qcad: No such file or directory
[email protected]:~$ ./qcad-2.2.2.0-1-prof.linux.x86
bash: ./qcad-2.2.2.0-1-prof.linux.x86: Is a directory
Posted: Wed Nov 02, 2011 9:02 pm
I don't see the QCAD binary (the actual application) which should be in that directory. It's a file called 'qcad'.
You might have accidentally deleted it or moved it to another place. Please download and install QCAD again.
Posted: Wed Nov 02, 2011 9:33 pm
by RayArdia
Full marks! 'qcad' found in backup, don't know how it was deleted but is now back in its correct slot!
Many thanks - now all I have to do is find all my drawings in backup!
Ray
