greetings from the delta of mississippi usa
drsorey
Post by drsorey » Sat Jul 09, 2022 4:01 pm
I am 69 year old retiree. I have used mostly CorelDraw and some older 2d Autocad. I use qcad pro for metal and woodworking projects.
Re: greetings from the delta of mississippi usa
Post by Husky » Sat Jul 09, 2022 6:49 pm
Thanks for introducing yourself. Welcome to the QCAD forum!
