Cutting an encoder disk
RobB
Post by RobB » Wed Aug 13, 2025 10:50 am
As the attached dxf file shows, set to 'outside', the milling router gets confused about being inside or outside a hole, although all slots are identical.
This is with the setting 'LinuxCNC (Offset) [mm], but other settings have a similar effect.
Anyway I can fix this? Removing the outer circle and trying cutting 'inside' does not help.
Regards, Robert
NB
Version:
3.32.2.0 (3.32.2)
Internet:
QCAD.org
Build Date:
Feb 20 2025
Revision:
6616def
Qt Version:
5.14.2
Architecture:
x86_64
Compiler:
gcc 5.4.0
160-03 CNC Racking 32-slot encoder optocoupler support.dxf
(496.19 KiB) Downloaded 37 times
Linux Mint 20 , qcadcam-3.24.3.10-pro-linux-x86_64
Re: Cutting an encoder disk
Post by andrew » Wed Aug 13, 2025 11:56 am
Please check your design for duplicate lines (Modify > Detection > Detect Duplicates).
RobB
Post by RobB » Wed Aug 13, 2025 12:29 pm
Thanks, that was the problem.
Rotated too many times...
Regards, Robert
Return to “QCAD/CAM”
