Updating plunge rate
Moderator / Drawing Help
Post by Clive » Wed Aug 30, 2017 9:01 pm
I've noticed if I update the plunge rate for a cam tool it doesn't dynamically update toolpaths which are using the same tool - in this example T1.
I had to go through and update more than 20 toolpaths manually - should this be the case or am I missing something here?
CAM Q1.jpg (67.44 KiB) Viewed 4194 times
CAM Q2.jpg (11.71 KiB) Viewed 4203 times
Return to “QCAD/CAM”
