Is there a way to copy a selection including it's toolpaths ?
i.e I f you need to cut numerous copies of the same item is there a way to copy the toolpaths or do they need to be individually recreated. Have tried copy and paste but toolpaths are not carried over.
Am very new to this so please excuse my ignorance.
Ta
Copy selection with toolpath
Re: Copy selection with toolpath
You cannot copy generated toolpaths. Every toolpath is based on a set of original drawing entities.
Note that you can select multiple contours and create one single toolpath from them. QCAD/CAM will then process each contour separately.
