Using SnapShot 3.22.1.2, Windows 10.
I got very excited about the automatic nesting mentioned in the Changelog and downloaded the SnapShot 3.22.1.2 right away to check it out. I could not find the new nesting feature in the CAM menu, i guess it not ready yet. I will "patiently" wait until the next SnapShot release.
But I found that if i have Toolpaths showing on screen, when i zoom or pan, when the starting point of the toolpath (usually 0,0) goes out of the screen, all of the toolpaths dissapear. They will re-appear if i zoom or pan again, when the starting point is back on screen.
Toolpaths dissapear in SnapShot 3.22.1.2
Ico
Using QCAD/CAM 3.23 on Win10 64-bit.
Re: Toolpaths dissapear in SnapShot 3.22.1.2
Please attach or e-mail your file, thanks.
Ico
Here is one of the files. Tool path visibility is on, and if I zoom or pan so the 0,0 is outside of the screen, the tollpath dissapears.
- Rig Skull.dxf
- (1.11 MiB) Downloaded 847 times
Thanks. Bug report at:
https://qcad.org/bugtracker/index.php?d ... sk_id=1909
As a workaround, make sure that CAM toolpaths are on when saving.
Ico
Thanks Andrew!
I have some more info on this, hopefully it will help you to narrow down the problem:
Using the same drawing, I deleted the existing toolpaths, and re-did them again. If I change the order of them from the toolpath widget, then they will behave properly and not dissappear while zooming. But if I save the drawing, close it and re-open it, they start disappearing again. Also when I save the drawing with toolpaths on, and re-open it, the toolpaths are off. It seems that it does not retain the state of the toolpaths visibility.
