[Solved] - Nesting problem
ukibrian
Post by ukibrian » Fri Nov 15, 2019 10:38 am
I am trying to nest the small rectangles into the larger sheet but I keep getting the message-
"Nesting canceled. No solution found."
I select all the smaller parts, left click the larger one and then right click to start but just get the error
nest.dxf
(105.88 KiB) Downloaded 60 times
Screenshot (2).png (179.44 KiB) Viewed 1593 times
Re: Nesting problem
Post by andrew » Fri Nov 15, 2019 10:44 am
I cannot reproduce this problem here. What are your exact nesting parameters? Please check the options toolbar at the top before right-clicking or include a screenshot of the application in that state. Thanks.
Screenshot 2019-11-15 at 10.44.54.png (14.35 KiB) Viewed 1590 times
ukibrian
Re: Nesting problem
Post by ukibrian » Fri Nov 15, 2019 11:17 am
Thanks for the quick reply.
This is just before I right click and get the error message.
Screenshot (3).png (193.03 KiB) Viewed 1588 times
Re: Nesting problem
Post by andrew » Fri Nov 15, 2019 11:27 am
Thanks. I still cannot reproduce.
Could you also attach a screenshot of your nesting preferences under Edit > Application Preferences > CAM > Nesting.
ukibrian
Re: Nesting problem
Post by ukibrian » Fri Nov 15, 2019 11:36 am
see attached.
Screenshot (4).png (215.78 KiB) Viewed 1586 times
Re: Nesting problem
Post by andrew » Fri Nov 15, 2019 11:56 am
Thanks. This looks all fine.
Some things you can try:
- Set the number of threads manually to 1 or 2 in the preferences
- Change the strategy in the options toolbar from "Hull" to "Align"
- Reset your QCAD/CAM configuration:
- Try it on another computer if possible
- Try the latest snapshot release 3.23.0.6 (available from your download link)
If you can't get it to work on your system, please contact us for a refund.
ukibrian
Re: Nesting problem
Post by ukibrian » Fri Nov 15, 2019 1:00 pm
Thanks Andrew.
I have tried everything but the new PC but to no avail... I will try when I get home.
ukibrian
Re: Nesting problem
Post by ukibrian » Sun Nov 17, 2019 11:06 am
Still no joy at home. Looks like I will have to go back to the old way.....
If there is any information I can give that may help find a solution please do not hesitate to contact me.
Re: Nesting problem
Post by Husky » Sun Nov 17, 2019 6:06 pm
If I do something on purpose wrongly then I'm able to reproduce the message. e_surprised
1.
I select all the smaller parts, left click inside the larger one but without selecting the contour, the command line tool will wrongly confirm "Sheet added".
Mouse right click will produce "Nesting canceled. No solution found"
2.
Same procedure but the left click to add the sheet is done anyplace else - not related to the target sheet rectangle - will produce the same message:
7 parts found
Sheet added.
If I select the sheet correctly - the nesting tool works like a charm ....
Question @ukibrian: If you left click the bigger part (Sheet) did you select the entities or just clicked in the middle of the rectangle?
ukibrian
Re: Nesting problem
Post by ukibrian » Mon Nov 18, 2019 8:53 am
Thanks Huskey.
All sorted, I was just left clicking inside the sheet. I did not know you had to do the edge......
Re: Sloved -Nesting problem
Post by andrew » Mon Nov 18, 2019 8:59 am
Excellent, nice catch Husky!
I'll check if the user manual can be updated to make that a bit clearer.
Return to “QCAD/CAM”
