Nesting Problem [ Solved in Snapshot 3.25.2.4.]
Post by John Hyslop » Tue Nov 17, 2020 11:33 am
Hi All
Just wondering if I'm doing something wrong here, I put 100 in nesting qty and it only fills part of the sheet...
I've just recently moved across to linux mint 20
Version:
3.25.2.0 (3.25.2)
Internet:
QCAD.org
Build Date:
Sep 4 2020
Revision:
4a61501
Qt Version:
4.8.4
Architecture:
x86_64
Compiler:
gcc 4.4.3
Re: Nesting Problem
Post by andrew » Tue Nov 17, 2020 12:37 pm
Thanks. I can reproduce this (under Linux only).
Bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2135
Re: Nesting Problem
Post by andrew » Wed Nov 18, 2020 5:54 pm
Snapshot 3.25.2.4 with a fix is now available.
Re: Nesting Problem [ Solved in Snapshot 3.25.2.4.]
Post by John Hyslop » Thu Dec 03, 2020 7:01 am
Thanks Andrew
Return to “QCAD/CAM”
