Post processor for Anilam Crusader 2
Arctic_Eddie
Post by Arctic_Eddie » Sat Dec 12, 2020 6:28 pm
I'm trying the QCAD/CAM trial and before buying the upgrade need to know that I can create a post processor file for the Anilam Crusader 2. Is there one available or which existing file can be modified for my use?
Re: Post processor for Anilam Crusader 2
Post by Husky » Sat Dec 12, 2020 7:20 pm
will this info help to answer your question?
https://qcad.org/en/qcad-cam-postprocessor
Arctic_Eddie
Post by Arctic_Eddie » Sat Dec 12, 2020 7:41 pm
Yes, that will be my guide if I have to build it from scratch. I would like to find a file in the existing list for a machine as similar to the Anilam 2 as possible and modify as needed. The Anilam is quite old and must be similar to something on the list. I know of a few things that need changing. I've been using DXF2GCODE converter but there are a few things that don't work right and can only be fixed by changing some Python code and re-building the MSI file. I'm trying to avoid that by doing it all in QCAD/CAM.
Thanks for reminding me about that guide.
Post by Husky » Sat Dec 12, 2020 9:30 pm
I'm pretty sure Andrew - the developer of QCAD/CAM has more and better suggestion than me how to modify the post processor for your machine. I'm certain he will join this conversation pretty soon. :wink:
Post by CVH » Sun Dec 13, 2020 3:06 am
Informational:
G-codes supported by Anilam Crusader 2:
http://faculty.etsu.edu/hemphill/entc37 ... top-o-page
And much more:
http://faculty.etsu.edu/hemphill/entc37 ... /index.htm
Seems pretty standard ... Although it may be necessary to use 2 digit codes like Gxx (G00, G01...)
Over to Andrew.
Arctic_Eddie
Post by Arctic_Eddie » Sun Dec 13, 2020 1:50 pm
I had already found those two links but it's good to be reminded. The files we've already used on the Anilam derived from DXF2GCODE use just a single digit and it works OK. Also found that the unit of measure is G70/G71 and it wants IJK numbers as absolute and the laser is activated using relays driven by M1/M2. I'm not aware of anything else, yet. I've studied the files and code for GrblMM and think I can use a copy and change just a few things. The only thing we're not determined yet is what character is used to signify a comment, *, $, or something else. The () pair does not seem to be recognized as expected.
Post by CVH » Sun Dec 13, 2020 4:57 pm
And: c. I or J commands that have zero (0) values can NOT be omitted.
http://faculty.etsu.edu/hemphill/entc37 ... /chp07.htm
Surely '$' !
http://faculty.etsu.edu/hemphill/entc37 ... /chp08.htm
....Verbose format (with each variable commented):
Regards
Arctic_Eddie
Post by Arctic_Eddie » Sun Dec 13, 2020 5:34 pm
Got it. Things are looking up now. Will upgrade my program from PRO to CAM tomorrow.
The post processor file creation system seems versatile enough to handle a water wheel driven putty knife.
Return to “QCAD/CAM”
