this is my first post for cnc
yowhi
Post by yowhi » Thu Jun 17, 2021 8:53 am
hi all!
i love qcad cause qcad resolved my fear about cad software like autocad,etc..!
really appreciate qcad team!
recently i bought the cnc machine the nomad 3 from carbide3d
so i upgrade qcad to qcad/cam for my first cnc machine :o
qcam was easy to use as qcad and intuitive interface for 3d simulation so i don't need use the other software like
meshcam or freecad,fusion360..
i just want to done everyworks in qcad/cam but i can't export recognizable gcode for my machine.
postprocessor was g-code(offset)mm and GRBL(offset)mm .
i hope qcam support listing post process for carbide3d. i think carbide3d user should have to know qcad/cam!
some of partner cam software like meshcam for carbide3d but i don't want to use other cam.
i attatched my test dxf and nc file from qcad and gcode nc file from carbide3d supported program
and the file "Cabide3D-MM" is script/postprocess in meshcam folder the suppoted carbide3d
please check these files
thank you
Carbide3D-MM.txt
(923 Bytes) Downloaded 357 times
carbide_creat_test_postprocess.nc
(60.17 KiB) Downloaded 338 times
test_postprocess.dxf
(1.44 MiB) Downloaded 356 times
Qcad_test_postprocess_GRBL.nc
(23.56 KiB) Downloaded 331 times
Qcad_test_postprocess_gcode.nc
(31.02 KiB) Downloaded 335 times
Re: this is my first post for cnc
Post by andrew » Fri Jun 18, 2021 9:21 am
Thank you for your kind feedback and your information about the controller you are using.
I've attached a post processor based on the one you've posted. However, there is some inconsistency between the post processor you posted and the example file, so this should be considered to be a starting point for a post processor for Carbide 3D.
Please save the attached file into the postprocessors directory of your QCAD/CAM installation and choose the configuration "Carbide 3D [mm]" when adding tools / toolpaths.
Carbide3DMM.js
(1.4 KiB) Downloaded 351 times
yowhi
Post by yowhi » Sat Jun 19, 2021 6:56 am
oh! god! thank you so much andrew!!
i'll check it tonight!!!
thank you again!
yowhi
Post by yowhi » Tue Dec 14, 2021 3:18 pm
sadley it's not work ..
i hope qcad/cam add more machine profile for cam
thanks
Post by andrew » Tue Dec 14, 2021 3:24 pm
Thanks for letting us know. We'd need more information (such as warnings, errors, etc.) for us to fix the post processor.
Please understand that without any further information, we will drop that post processor from future QCAD/CAM releases.
Return to “QCAD/CAM”
