Compensation for every toolpath?
Dacicusan
Post by Dacicusan » Tue Feb 08, 2022 11:12 am
I'm creating a post-processor and I do need to write the side compensation of the tool on every created toolpath. Right now Qcad/CAM it is writing the compensation only when it is changing the side of the machining.
I do have this peace of code:
    // Tool Compensation LEFT | C=2
    this.linearMoveCompensationLeft = [
        "C=2" //OLD:"G41 [X] [Y]"
    // Tool Compensation RIGHT  C=1
    this.linearMoveCompensationRight = [
        "C=1" //OLD:"G42 [X] [Y]"
    // Tool Compensation OFF  C=0
    this.linearMoveCompensationOff = [
        "C=0", //OLD:"G40"
The problem is that I don't understand how to create a variable that can read this inputs and write the desired compensation on the toolpath header like C=2, C=1 or C=0, for every toolpath created.
Best regards.
Re: Compensation for every toolpath?
Post by CVH » Wed Feb 09, 2022 1:40 pm
Correct: G40, G41 and G42 are modal.
Meaning that in standard G-code they stay active as long as they aren't changed.
BTW: I am convinced that your machine can load normal G-code files.
Also remark that all 3 have an XY component.
Some dialecs may also require an explicit G1.
The compensation of G41/2 will be nothing initially.
The cutter will only be fully compensated at the end of the compensation move.
Or fully cancelled with G40.
A linearMoveCompensationLeft is simply what its says:
- A linear move to a point in X/Y
- Apply a left compensation so the motion actually ends 'left' from X/Y
I am only guessing that "C=0..2" means none, right or left compensation mode.
But I don't see a compensation move.
linearMoveCompensationLeft doesn't mean 'I am in this or that compensation mode'. :wink:
I suppose this.getSide(); returns the cutter radius compensation side of the current toolpath.
What is written as toolpath header is defined in: this.toolpathHeader = [...];
The real solution may be overriding writing the toolpath header.
MyPost.prototype.writeToolpathHeader = function() {...};
Return to “QCAD/CAM”
