In my opinion, the CAM module is one of the very strong points of QCAD. It makes QCAD positively different from many other CAD programs available. It was also an argument for me that made my choice regarding the QCAD purchase. I would like to ask if there are any new functions / options planned in the CAM module in the future upgrades.
Best Regards
Konrad
Question - what future plans for the CAM module
Re: Question - what future plans for the CAM module
The main priority at the moment is porting QCAD an QCAD/CAM to Qt 6 which unfortunately is a major undertaking due to Qt deprecating a vital module. New features for QCAD/CAM will be considered after this.
Thank you for your response. I wish you quick and trouble-free completion of this process.
How advanced are you in this operation?
Regards
Konrad
Regards
Konrad
I started to port QCAD from QScriptEngine (Qt 4 and 5) to QJSEngine (Qt 6) about 6 months ago. This process involves creating script bindings for the entire Qt API for JavaScript from scratch. These bindings were previously readily available for Qt 4/5. I'm far enough to know now that the problem can indeed be solved but it's a major effort. Hopefully there will be light at the end of the tunnel towards the end of the year or beginning of next year.
Hi Andrew,
Does this help you at all? Specifically "No binding code is needed because it is done dynamically using the Qt meta object system"
https://doc.qt.io/qt-6/qjsengine.html#q ... ntegration
Yes, the basic interoperability between Qt and JavaScript is also possible with QJSEngine. But there are no existing bindings for the Qt API. Bindings are definitely needed since Qt classes do not expose their functions with Q_INVOKABLE and by far not all classes are even derived from QObject. We also need to be able to inherit JS classes from Qt classes, override events (paintEvent, mouseMoveEvent, ...), call the function of the base class ("super"), etc. This is where things get really complex.
