script bindings not available for qt 5.15.9
kenr
Post by kenr » Thu Jun 15, 2023 6:46 pm
Running on MACOS 10.15.7 Catalina with Xcode 12.4.
Downloaded qcad from https://github.com/qcad/qcad.
Followed the instructions at https://www.qcad.org/en/component/conte ... ces#macosx .
Qmake gave the following error message.
~/cad/qcad-master % qmake -r CONFIG+=ractivated
Reading /Users/admin/cad/qcad-master/src/src.pro
Reading /Users/admin/cad/qcad-master/src/3rdparty/3rdparty.pro
Project ERROR: Script bindings not available for Qt version 5.15.9. You can add them to src/3rdparty/qt-labs-qtscriptgenerator-5.15.9 or use another version of Qt.
I would not like to use another version of QT.
How can I find another script bindings?
Re: script bindings not available for qt 5.15.9
Post by CVH » Fri Jun 16, 2023 8:28 pm
Qt version 5.15.9.
Can't help you much, this are the supported platforms:
https://www.ribbonsoft.com/en/qcad-docu ... -platforms
kenr
Post by kenr » Mon Jun 19, 2023 5:28 pm
I notice that all the script generator files are the same so I created one for 5.15.9 which solved the problem.
emmesse
Post by emmesse » Sat Jun 24, 2023 8:25 am
how do you created one for 5.15.9 ?
can you tell more please ?
kenr
Post by kenr » Sat Jun 24, 2023 2:38 pm
I think I simply copied one of the others and renamed it. Look at the others and you'll see they are all the same except their name.
