Error Compiling QCAD with Qt 5.15.2 and MinGW on Windows
ady
Post by ady » Thu Nov 14, 2024 7:55 am
Environment:
Operating System: Windows 10/11
Qt Version: 5.15.2
MinGW Version: 8.1.0
QCAD Version: 3.31.2.0
Description:
I am trying to compile QCAD using Qt 5.15.2 and MinGW on Windows. I have successfully run the qmake command, but when I try to build the project using mingw32-make, I encounter an error related to the <limits> header file.
Steps to Reproduce:
Open Command Prompt.
Navigate to the QCAD source directory: D:\cad\qcad.
Run the qmake command: D:\cad\qcad>D:/Qt/5.15.2/mingw81_64/bin/qmake.exe -r CONFIG+=ractivated
D:\cad\qcad>D:/Qt/Tools/mingw810_64/bin/mingw32-make.exe -j32
Error Message:
In file included from dxflib.rc:5:
src/dl_dxf.h:30:10: fatal error: limits: No such file or directory
 #include <limits>
compilation terminated.
windres: preprocessing failed.
mingw32-make[4]: *** [Makefile.Release:82: D:/cad/qcad/release/dxflib_res.o] Error 1
mingw32-make[4]: Leaving directory 'D:/cad/qcad/src/3rdparty/dxflib'
mingw32-make[3]: *** [Makefile:45: release] Error 2
mingw32-make[3]: Leaving directory 'D:/cad/qcad/src/3rdparty/dxflib'
mingw32-make[2]: *** [Makefile:657: sub-dxflib-release_ordered] Error 2
mingw32-make[2]: Leaving directory 'D:/cad/qcad/src/3rdparty'
mingw32-make[1]: *** [Makefile:1118: sub-3rdparty-release_ordered] Error 2
mingw32-make[1]: Leaving directory 'D:/cad/qcad/src'
mingw32-make: *** [Makefile:457: sub-src-release_ordered] Error 2
What I Have Tried:
1.Ensured that the MinGW bin directory (D:/Qt/Tools/mingw810_64/bin and D:\Qt\5.15.2\mingw81_64\bin) is added to the system PATH.
2.Verified that the limits header file exists in the MinGW include directory (D:\Qt\Tools\mingw810_64\lib\gcc\x86_64-w64-mingw32\8.1.0\include\c++).
3.Cleaned the project and rebuilt it using mingw32-make clean followed by mingw32-make.
4.I have previously compiled QCAD using Qt 5.15.2 and MinGW on Ubuntu, and it was successful.
