Problems
Argos
Problems
Post by Argos » Sat Feb 11, 2017 9:54 am
I have the community version of QCAD 5.5, how to avoid after a while to have to restart the software to make it work. Thank you
Re: Problems
Post by Husky » Sat Feb 11, 2017 8:28 pm
Argos wrote:Hello,
... the current Version of QCad is 3.16.5
You can download the current Version as a Trial Version which can be turned to a CE version from this website:
http://www.qcad.org/en/qcad-downloads-trial
Argos wrote:... how to avoid after a while to have to restart the software to make it work.
What means "to make it work"? The Trial Pro features will expire after a couple minutes and you have to restart QCAD to test further the Pro features. We are talking about that?
Argos
Re: Problems
Post by Argos » Sat Feb 11, 2017 9:47 pm
Hello
Thank you for your answers, yes that's it; Restart QCad every 10 minutes
Re: Problems
Post by Husky » Sun Feb 12, 2017 12:38 am
Argos wrote:Restart QCad every 10 minutes
If you launch a trial version of qcad it will show you a window at the right lower corner like this one:
You can remove the trial features with "Remove" (eventually you need to run the application as an Administrator). That will bring QCAD permanently in the free "Community Edition" Mode.
If you are satisfied with the Professional features and you will use them without limitations then you can use the "Buy" button to purchase the software.
Argos
Re: Problems
Post by Argos » Sun Feb 12, 2017 8:30 am
Thanks for this info, what is the difference between the pro version and the community?
Re: Problems
Post by Husky » Sun Feb 12, 2017 10:08 am
Argos wrote:Thanks for this info, what is the difference between the pro version and the community?
You are welcome!
Here is a list with all QCAD Features:
http://www.qcad.org/en/qcad-documentation/qcad-features
Features in italic are available in QCAD Professional only.
Argos
Re: Problems
Post by Argos » Sun Feb 12, 2017 2:22 pm
Ok so thank you for your help
Good week-end
