[SOLVED] Cannot find -lQtHelp
massimo
Post by massimo » Mon Mar 27, 2017 3:05 pm
today the build is failing:
g++ -Wl,-O1 -shared -o libspatialindexnavel.so release/BulkLoader.o release/Index.o release/Leaf.o release/Node.o release/RTree.o release/Statistics.o release/LineSegment.o release/MovingPoint.o release/MovingRegion.o release/Point.o release/Region.o release/SpatialIndexImpl.o release/TimePoint.o release/TimeRegion.o release/Buffer.o release/DiskStorageManager.o release/MemoryStorageManager.o release/RandomEvictionsBuffer.o release/rand48.o release/Tools.o   -L/usr/lib64/qt4 -L/home/mb/src/other/qcad/release -lQtWebKit -L/usr/lib64/qt4 -lQtScriptTools -lQtScript -lQtSvg -lQtSql -L/usr/lib64/mysql -lQtXmlPatterns -lQtOpenGL -lQtNetwork -lQtUiTools -L/var/tmp/portage/dev-qt/designer-4.8.7/work/qt-everywhere-opensource-src-4.8.7-abi_x86_64.amd64/lib -lQtXml -lQtGui -lQtCore -lGL -lpthread -lQtDesigner -lQtHelp
/usr/lib/gcc/x86_64-pc-linux-gnu/4.9.4/../../../../x86_64-pc-linux-gnu/bin/ld: cannot find -lQtHelp
This is on Gentoo, I tried gcc 5.4.0 and 4.8.3, there are 2 slotted Qt installed 4.8.7-r2 and 5.7.1-r2.
Community Version 3.28.2.0, Gentoo Linux on amd64
massimo
Re: Cannot find -lQtHelp
Post by massimo » Mon Mar 27, 2017 3:10 pm
I wonder about that -L/var/tmp/portage/dev-qt/designer-4.8.7/work/ path that was only temporary when building Qt. Seems to be generated by qmake -r.
$ qmake --version
QMake version 2.01a
Using Qt version 4.8.7 in /usr/lib64/qt4
massimo
Post by massimo » Tue Mar 28, 2017 10:04 am
Ok, dev-qt/qthelp-4.8.7 is a separate package, works after installation.
