Lead arrows for text in drawings. (solved)
Jim0000
Post by Jim0000 » Sat Apr 01, 2017 12:48 am
Is there a feature to properly draw lead arrows between descriptive text and parts of a drawing?
For example, what is the correct way to do what I have done here in this example?:
.dxf file attached.
Blade fixing.dxf
(36.93 KiB) Downloaded 480 times
Re: Lead arrows for text in drawings.
Post by Husky » Sat Apr 01, 2017 1:48 am
You can use the "Leader" tool which is part of the Dimension set:
Jim0000
Post by Jim0000 » Sat Apr 01, 2017 4:18 am
Got it, thanks Husky.
Jim0000
Post by Jim0000 » Sat Apr 01, 2017 4:19 am
