parallel MOVE of a line and snap ends to endpoint
Krischu
Post by Krischu » Sun Jul 07, 2019 9:02 am
Bildschirmfoto 2019-07-07 um 10.03.58.png (8.16 KiB) Viewed 5079 times
I had to move several of these lines a few millimeters. These "ears" around a development of a sheet metal had to be lengthened from 5mm to 7mm. So I lenghthened th short pieces and wanted to move the long ones (red line) to the position of the dotted line.
I ended up in deleting the long lines and drawing all long lines again freshly, since I had a better "snap protocol" than the one I had when using the MOVE protocol. Or what would be the easiest way to move the red lines to the dotted position?
Christoph
Christoph
Re: parallel MOVE of a line and snap ends to endpoint
Post by Husky » Sun Jul 07, 2019 5:58 pm
Probably I would use the "Stretch" tool combined with the "Coordinate" snap.
https://www.qcad.org/doc/qcad/latest/reference/en/
No need to lengthen, shorten, moving, deleting blablabla multiple entities .... :wink:
