Morning,.
When I open a design from Anyconvert, from DWG to DXF, the specials caracters appears truncated. Please, could anybod help me how tô repair that.
(solved) Truncated caracters
- Active Member
Re: Truncated caracters
please attache the dwg and the dxf to this post so that we can see what happens ...
- Active Member
Morning,
Here the files.
Here the files.
- 07-TELHADO HIDRÁULICA - AVENIDA MERITI - R3.dwg
- (564.59 KiB) Downloaded 363 times
- TELHADO HIDRÁULICA - AVENIDA MERITI - R3.dxf
- (834.02 KiB) Downloaded 373 times
The font used ("Romans") does not contain those international characters. You can use Edit > Substitute Fonts to change all fonts for example to "Standard" or to a TTF font which will likely contain the characters.
- Active Member
Hi Andrew
Specials caracters are OK, I am using Standart or Unicore fonts.
I am so glad, thank you so much.
