[CLOSED] QCAD does not open
scrouthtv
Post by scrouthtv » Fri Aug 28, 2020 4:42 pm
I just installed QCAD 3.25.0 on Linux 5.8.3-arch1-1.
When I try to run it from the desktop, nothing happens (I waited for 40 minutes).
When I run it from the command line, I get these two lines of output, and nothing happens:
 ~ qcad
QCAD version  3.25.0
Warning:  RPropertyTypeId::generateId: property already initialized:  7RObject : "" : "Invisible"
What could be causing this?
Could it be possible that my hardware can not run this software? This is an old ThinkPad with only an i5 M 520, Intel Core Graphics and 6 GB of RAM.
Thanks for any help in advance.
Re: QCAD does not open
Post by andrew » Fri Aug 28, 2020 8:01 pm
Which package (file name) are you using? Did you try the alternative packages (Qt 5, Qt 4)?
scrouthtv
Post by scrouthtv » Sat Sep 05, 2020 7:52 am
There are no alternative packages. The package is called qcad-3.25.0.0-3-x86_64.pkg.tar.zst
I can't post more information because it gets detected as spam, however the package depends on Qt 5 and there are no Qt 4 alternatives
Post by andrew » Sat Sep 05, 2020 6:33 pm
You are using a 3rd party package of the QCAD Community Edition. We cannot offer any kind of support for such packages. Please contact the distributor.
I will move this thread to the appropriate forum for the QCAD Community Edition.
scrouthtv
Post by scrouthtv » Thu Sep 10, 2020 1:13 pm
Looks like it got fixed by the recent update. closing
