Qcad Post-purchase use problem
fchaoyang
Post by fchaoyang » Fri Jun 28, 2024 4:08 am
May I ask if I can use the dwg2pdf command if I buy the following attachment? What I need to buy is the Professional version deployed on linux, I want to know if this purchase is for permanent use? Or do you buy it once a year? Then I bought the Pro version of linux, can I only deploy one server with one license, or can I deploy multiple servers with one license. There is also a problem, because I need to use the dwg2pdf command, do not know whether the linux professional version has this function, online anxious, very anxious!! Please reply to me as soon as possible
fchaoyang
Re: Qcad Post-purchase use problem
Post by fchaoyang » Fri Jun 28, 2024 4:21 am
QCAD Professional
(Download)
CNY 300.00
Single user license.
Windows, macOS, Linux.
One year of updates.
Delivery as download.
Post by CVH » Fri Jun 28, 2024 4:45 am
Please read: https://www.ribbonsoft.com/en/documentation/license
QCAD Professional single user licenses are valid for one single user.
A license may be used to install and use QCAD Professional on multiple computers and operating systems as long as there is only one user.
A Pro licence lets you download QCAD Professional for any supported operating system (Access is limited to 1 year)
Meaning that a licence is forever, one can download updates for the installed package(s) for 1 year.
A personal licence is personal to you only.
There is a reduction code mailed to you for when you want to renew your access to downloads.
I think that you need a QCAD Professional Server License, the pricing is then per server.
QCAD Professional server licenses allow the use of QCAD Professional on a web server to process or generate data as part of a web service.
All the Pro packages include all functionality ... dwg2pdf for that matter. :wink:
fchaoyang
Post by fchaoyang » Fri Jun 28, 2024 4:55 am
QCAD Professional (Access limited to 1 year)? Can you download updates of installed packages for 1 year? This means that after I purchase, I will be given a connection, this link can access for a year, even if the Qcad with the new, I can also download the latest software package according to this website. So this license is permanent, right? Simply put, will Qcad deployed on linux still work a year after purchase?
Post by CVH » Fri Jun 28, 2024 5:20 am
Again, yes,
The licence is forever, you yourself may use your personal version of QCAD Pro bought with a single user licence forever.
And on all computers where you have installed it for personal usage.
The only thing that stops after 1 year is your access to your personal download page.
A link will be supplied after purchase.
On that download page there are again all QCAD installations listed as on the download site for QCAD trial.
A personal licence is not intended for installation on a server and QCAD Pro itself may never be distributed by you.
Probably yes, this is only limited by the updates to the Linux package.
If it works now then it will work within 10 years just the same if the OS platform doesn't change too much.
As example:
My QCAD Win 32bit installation is still running on a Win 7 operating system.
Meanwhile support for Win 7 has ceased by MS but everything related to CAD is still running fine.
Return to “Chat”
