Is there a way to toggle between english and metric in QCad?
I'm currently stuck in inches and no matter what I set the drawing units to in Edit->General->Drawing_Unit it stays in inches.
I've looked at the documentation and searched around the forum and I seem to be doing what I should be doing...
What am I missing???
[solved] Switch between metric & english?
typhon62
- Registered Member
Re: Switch between metric & english?
To change the unit for the whole drawing please use the converting tool in QCAD. Menu / Edit / Convert Drawing Unit. It will convert the whole drawing inclusive the proper scaling regarding the change.
Yes.
That will simply explained only change the name of the unit. e.g. a 100 inch line is then 100 mm.
typhon62
- Registered Member
Awesome, thanks!
iOne iTwo
- Active Member
Re: [solved] Switch between metric & english?
It it possible to have a drawing with mixed units?
Say a 250mm x 250mm rectangle located 5' from the edge of a box,
and dimensioned in mm ? Is there a quick shortcut to flip to entering in a different unit system?
Is it possible for a dimension to be shown in more than one unit, e.g.
3.18mm (1.5") (1 1/2")
For unrelated questions it is best that you open a new topic.
CAD is basically unit-less, the unit is nothing more than the name you give a value.
We can not enter 5' in a drawing in mm.
BTW that would result in 60 units (=mm) because the foot sign is considered as a multiplier with 12.
We can enter 5x12x25.4 because most fields can handle equations.
For a solution see Feature request + workaround
No, not really.
No that is not possible.
