dimension
SMR
dimension
Post by SMR » Thu May 11, 2023 12:20 am
QCAD Professional
Version:
3.28.1.0 (3.28.1)
Windows 11
I am a newbie doing something wrong. When I ask for dimension and click on a point it does not enter a position but starts a new shape.
Re: dimension
Post by Husky » Thu May 11, 2023 12:42 am
I assume you are trying to determine the dimensioning with the right mouse button. Use instead the left mouse button and it will work.
Re: dimension
Post by CVH » Thu May 11, 2023 5:48 am
I think this is all intended behavior.
When you start drawing a new dimension entity and click the first point a preview appears of the dimension to create.
Have a closer look at the mouse icon in the Status Bar and the text beside it (usually bottom center of your screen).
The tool tips beside the mouse icon will guide you through the creation process.
For an Aligned Dimension (LA) the left mouse button tool tips are :
- First extension line origin
- Second extension line origin
- Dimension line location
And this cycles until the tool is closed.
The right mouse button tool tips swaps between:
- Back (one step back in the creation process)
- Cancel
Remark that this is for adding dimensions to your drawing.
Use the Info tools for indicative measuring.
SMR
Re: dimension
Post by SMR » Thu May 11, 2023 11:22 pm
This does not work that way. The bottom line says first dimension line location and when I left click with the mouse at a position that changes to second dimension line position but the mouse begins drawing a figure. if I continue to the third element I get a new rectangle. None of the positions fill in at the top boxes.
Re: dimension
Post by Husky » Fri May 12, 2023 12:42 am
QCAD already forms the dimension with the given information ...
Could it be that your Label size is to small to see? Menu/Drawing Preferences/Dimension Settings/Text Hight
If this video still not solves the issue please attache the drawing in question to your post. Thank you.
SMR
Re: dimension
Post by SMR » Fri May 12, 2023 4:17 am
I click on dimension, vertical, put click the cursor on a point and it says select second point but when I move the cursor I get a new line
I have no idea how to give you the image. Neither print screen nor CTRL C followed by CTRL V puts the image here
Re: dimension
Post by CVH » Fri May 12, 2023 4:41 am
Probably the dimension line.
If you move the third point aside, do you get extension lines too?
First have a look at the drawing dimension settings like Husky pointed out:
- Menu Edit .. Drawing Preferences .. Dimension Settings .. Sizes .. Text height
- Menu Edit .. Drawing Preferences .. Dimension Settings .. Sizes .. Size scale factor
- Menu Edit .. Drawing Preferences .. Dimension Settings .. Label .. Label font
Text height times Size scale factor should be a value that is meaningful and visible in your drawing.
Label font should be a well-known font that you know for sure represents something with numbers.
You need to save the screen grab as an image and attach that to your post.
But you could also attach the file or part of it so we can have a look ourselves.
SMR
Re: dimension
Post by SMR » Fri May 12, 2023 4:47 am
Transaction failed. Please check for block recursions and locked or invisible layers or blocks
Does this explain anything?
Re: dimension
Post by CVH » Fri May 12, 2023 4:54 am
Yes, you probably have the current active layer hidden, frozen or locked.
See Layer List, the current active layer has a pencil icon near to it.
Re: dimension
Post by Husky » Fri May 12, 2023 8:01 am
Yes and no. It explains you are facing an additional but unrelated issue. You told us that during the dimensioning other shapes are created like rectangle etc. That isn't possible with an invisible, frozen or locked layer.
You may try it again ...
1. make sure your active layer is not invisible, frozen or locked.
2. do a dimensioning according to my posted video.
SMR
Re: dimension
Post by SMR » Fri May 12, 2023 7:47 pm
Really sorry I ever purchased this program. I have one layer, visible and active. I will repeat that when try to do what you say, the command line says First extension line origin but the mouse begins drawing a new line after I click on a point and more it.
Re: dimension
Post by Husky » Fri May 12, 2023 9:34 pm
To get a better understanding of the situation. You told us you are a "Newbie". Nothing wrong with that statement! Everybody of us was at one point a newbie. However - do you mean by that new to QCAD or new to CAD in general?
SMR
Re: dimension
Post by SMR » Fri May 12, 2023 11:25 pm
I am a scientist and electrical engineer. I have used a variety of computer aided design programs over the years but have only a little experience with mechanical design.
SMR
Re: dimension
Post by SMR » Fri May 12, 2023 11:32 pm
I still do not know how to post a screen shot. Printscreen and Ctrl V do not work.
SMR
Re: dimension
Post by SMR » Sat May 13, 2023 12:03 am
This will be my last post before I discard the program. I will reiterate for the once last time that I ask for vertical dimension, the command line says set first extension, I click on that, it says set second extension and when I move the mouse it draws a line. The command line is not being followed by the program. If there is no answer to this I will just discard the program. I cannot waste more time one it.
Return to “Chat”
