I was wondering if there is a way to make background images lighter, like kind of ghosted, so when you lay lines, you can see the line better. I didn't see anything in the book, I may have missed it.
Thank You
Dan
[solved] Background Image
Re: Background Image
Yes, you can change the fade property.
- Select the image
- Change the "Fade" property using the property editor.
For example 10 means 10% faded, 100 would mean 100% faded or completely invisible.
- Select the image
Thank You!
Dan
Dan
