[solved] Copy & Paste changing size/scale
Rob Martin
Post by Rob Martin » Wed Nov 20, 2024 4:24 am
I have been using QCad to draw a property and basic home/shed layouts.
I was able to copy and paste components and text on the various drawings. Now it will copy and paste but at a very small size. For example text copied at 500 height (Very large property drawn at 1:1) will paste at height 4.665. Similar issue for copying features such as brick pillars etc.
I am sure I've accidentally changed a setting etc?
Any help appreciated
Rob
Re: Copy & Paste changing size/scale
Post by Husky » Wed Nov 20, 2024 5:12 am
when you trigger "Paste" an option bar pops up usually at the top of your drawing area.
In this Option bar you will find a scale option which should be set to 1 or 1:1.
Rob Martin
Post by Rob Martin » Wed Nov 20, 2024 5:51 am
Fixed, so easy. Cannot thank you enough :)
Return to “Chat”
