Dimension value is overlapped when some files viewed by QCAD
Have some feedback on the RibbonSoft web site? Want something added to the QCAD online manual? Post it here!
yongjun.qi
Post by yongjun.qi » Thu Dec 23, 2021 3:45 am
The problem as the subject, the dimension values is shown right when the file open by other software, please see the attachments.
設計圖紙(2).dwg
(541.53 KiB) Downloaded 1332 times
Re: Dimension value is overlapped when some files viewed by QCAD
Post by Husky » Thu Dec 23, 2021 6:29 am
QCAD is a 2D program! Your drawing contains 3D entities what leads understandably to unexpected behavior in QCAD.
If you flatten it to 2D (Menu/Misc/Modify), change the Dim settings from Arrow to Tick, reduce the size of the DIM text from 3 to 2.25, remove the double dimensioning then ..................... it will work just fine in QCAD. :wink:
Return to “Site Feedback”
