parallel tool
J-J
Moderator
parallel tool
Post by J-J » Thu Jul 23, 2015 8:26 am
Since I installed 3.9.5, the parallel line tool is sometimes not active unless I click the 'auto' button:
for example, on new drawing, draw a random line, select parallel distance tool, the distance value cannot be edited, then if I click on the first line, the preview does not show but a parallel will be drawn at the recalled value, after you quit the tool...
I kept 3.9.4 on the laptop, the same test will work as expected
Both machines are under Win 7-64
JJ Win7 pro-64
Re: parallel tool
Post by andrew » Fri Jul 24, 2015 10:12 am
Thanks. This seems to be caused by the recent update to Qt 4.8.7. I will revert to the good old Qt 4.7.4 for the next Windows release.
Re: parallel tool
Post by andrew » Fri Jul 24, 2015 10:15 am
Re: parallel tool
Post by andrew » Fri Jul 24, 2015 3:52 pm
QCAD 3.9.6 (unter Windows based on Qt 4.7.4) has been released and should fix this issue.
J-J
Moderator
Re: parallel tool
Post by J-J » Fri Jul 24, 2015 10:14 pm
So far, so good, thanks Andrew :D
JJ Win7 pro-64
