[solved] Text Width not being retained.
BarryW
Post by BarryW » Sat Nov 21, 2015 8:05 pm
I think this is a bug, but could someone else confirm :
Type some text;
Edit the x-scale = 0.75;
Notice that the text has shrunk to 75% width;
Save the drawing;
Notice the text is still at 75% after the save;
Close the drawing.
Re-open the drawing;
Now the text is back at 100% width, x scale is now 1 again.
Block Attributes do the same;
DWG or DXF, same problem;
Running Windows 7, with Qcad 12.1,
thanks,
Barry
Re: Text Width not being retained.
Post by andrew » Sat Nov 21, 2015 8:32 pm
Yes, I can confirm this for simple texts. As an immediate workaround, you might want to change the property "Simple" to "No".
Bug report at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1308
BarryW
Post by BarryW » Sat Nov 21, 2015 8:53 pm
Wow that was quick,
Thanks for that info,
Barry.
BarryW
Post by BarryW » Wed Nov 25, 2015 6:54 pm
All fixed now in 3.12.3; many thanks for the speedy repair,
Barry.
Post by andrew » Wed Nov 25, 2015 7:33 pm
OK, thanks for the confirmation.
BarryW
Re: [solved] Text Width not being retained.
Post by BarryW » Sun Jul 23, 2017 11:27 pm
Hi Andrew,
The bug is back again in 3.17.3, ie Text Width reverts to 1,
thanks,
Barry.
