Space doens't focus on command line (Linux mate)
renod
Post by renod » Thu Jul 28, 2016 12:06 pm
Space doens't focus anymore on command line (Linux mate).
What can I do?
Thank you. R.
Moderator
Re: Space doens't focus on command line (Linux mate)
Post by Clive » Thu Jul 28, 2016 6:19 pm
Hi renod
Have you tried ?
Main menu > Edit > Application Preferences > Tool Settings - type and search 'Focus on command line' restore the default settings and click apply.
view focus on command line.jpg (86.87 KiB) Viewed 21213 times
Let us know if this does the trick or not.
renod
Post by renod » Thu Jul 28, 2016 11:21 pm
Thanks Clive :)
I did restore the settings but without expected results.
Even CTRL-M doens't work.
But others shortcuts like CTRL-N works...
Version:
3.14.3.0 (3.14.3)
R.
Ps: Clive do you use a linux version? Because this problem is not new for me but I don't remenber after witch update this problem appears...
Moderator
Post by Clive » Fri Jul 29, 2016 8:55 am
renod wrote: I did restore the settings but without expected results.
Version:
3.14.3.0 (3.14.3)
Bug report added;
http://www.ribbonsoft.com/bugtracker/in ... sk_id=1451
renod wrote:Ps: Clive do you use a linux version? Because this problem is not new for me but I don't remenber after witch update this problem appears.
I use QCAD on Windows 10 and Linux Mint. I haven't experienced this problem on either operating systems.
Post by andrew » Fri Jul 29, 2016 10:19 am
Unfortunately, this problem cannot be reproduced here on any Linux system, including Ubuntu Linux with the Mate desktop (32bit or 64bit).
If you can submit additional information that might help to identify or reproduce the problem, please re-open the above task in the task tracker.
You might also want to try resetting your configuration (delete file ~/.config/QCAD/QCAD3.conf).
renod
Post by renod » Fri Jul 29, 2016 4:29 pm
Oki I got it.
The "space" shortcut focus on the command line only if the widget "command line" is not detached from the main window.
Thanks a lot for helping me to find a solution.
P.S. I did not try to reopen the bug because I don't use the latest version.
Reno.
Moderator
Post by Clive » Fri Jul 29, 2016 5:06 pm
renod wrote:The "space" shortcut focus on the command line only if the widget "command line" is not detached from the main window.
I see, I think that even if the command line is un-docked, you should still be able to focus on it by hitting the space bar. After testing I find that if I start a new drawing and the first thing i do is hit the space bar in an un-docked command line the focus goes there, but after that it doesn't work!
I think you've found a bug :cry:
renod
Post by renod » Fri Jul 29, 2016 5:33 pm
Hi Clive,
Since 20 years I'am using free software only (except some rare exceptions) and it's the first bug that I have discovered before another one did it :)
Reno.
Post by andrew » Fri Jul 29, 2016 7:40 pm
Thanks for the update.
Can you overwrite your file scripts/View/CommandLineFocus/CommandLineFocus.js with this file:
https://raw.githubusercontent.com/qcad/ ... neFocus.js
Please let me know if that fixes the problem on your system, thanks.
Moderator
Post by Clive » Sat Jul 30, 2016 11:40 am
andrew wrote:Please let me know if that fixes the problem on your system, thanks.
For me, it works just fine now on Linux Mint :) haven't tried on Windows yet.
@ Reno, let us know if this fix works for you too.
Moderator
Post by Clive » Sat Jul 30, 2016 12:49 pm
Update:
Works on Windows too, just fine.
renod
Post by renod » Sun Jul 31, 2016 6:54 pm
Just fine too :)
Linux 4.3.0-0.bpo.1-amd64 #1 SMP Debian 4.3.5-1~bpo8+1 (2016-02-23) x86_64 GNU/Linux
Mate.
Version Qcad-pro:
3.14.3.0 (3.14.3)
Reno.
Moderator
Post by Clive » Sun Jul 31, 2016 7:48 pm
Reno
Thank you for reporting back , very glad to hear it works for you too. :D
