Change Layer outline in DXF
slymn++
Post by slymn++ » Wed Aug 24, 2016 9:41 pm
Hello
I have some dxf files.
I want to find outline and change layer in dxf
How do you make automatically?
Re: Change Layer outline in DXF
Post by Husky » Wed Aug 24, 2016 11:44 pm
I don't think that I really understood what do you mean. Could you please post an example drawing and elaborate a little bit more about your plan. Thanks
slymn++
Post by slymn++ » Mon Aug 29, 2016 6:57 am
Hi
Thanks for your reply
I attached a sample dxf.
I want to change layer only outside rectangle. For example
in my attached dxf, Layer of outside rectangle is HOLES. But its should be LASER Layer by script
test.DXF
(14.42 KiB) Downloaded 1131 times
Post by Husky » Mon Aug 29, 2016 7:25 am
Hi slymn - thanks for the test drawing.
Ok, here is step by step how to change the Layer:
Menu / Select / (De)Select Couture,
Left Mouse click on the green couture,
Menu / View / Property Editor: look below General Properties for Layer, change the layer in the drop-down list from "Holes" to "Laser" - done.
slymn++
Post by slymn++ » Mon Aug 29, 2016 8:12 am
Hi Husky
Thanks for reply
I understand. I am a programmer. I have too dxf files.
I want to make automatically.
My software generate this dxf files. After I want to change layer with QCAD
slymn++
Post by slymn++ » Wed Sep 07, 2016 6:16 pm
Hi Husky
is it imposibble in QCAD?
Post by Husky » Wed Sep 07, 2016 6:24 pm
slymn++ wrote:Hi Husky
I don't know - I'm not a programmer. :(
Maybe Andrew can answer this question?
@Andrew: What do you think?
Post by andrew » Thu Sep 08, 2016 7:15 am
slymn++: QCAD comes with a very complete and powerful ECMAScript (JavaScript) interface with full access to the QCAD and Qt APIs:
http://www.qcad.org/en/qcad-documentati ... -scripting
The entire QCAD user interface and all tools are at the top level implemented as scripts. If you are willing to program, the only limit to what can be done using the script interface is your imagination.
