Hi all.
I am trialling the available low cost CAM software before purchasing.
I quite like Qcad itself. I have trial version 3.17.1.0. I tested on win 10, 7 and XP.
Trialling the Cam output I ran into a problem right away with curved objects, (gears).
Mach3 (V2.63) objects to the G code every time/file with the message - RijK words all missing for arcline XXX. and refused to load.
Thinking it might be my dxf file I tried a simple 2 circle file, (attached, as is the generated g code)
Mach3 gives the error objection to line 12 in this
With other Cam software I have so far trialled, this and other curved files cut without objection by Mach3.
Is it something I am doing, something wrong, or a limitation of the trial version, (code generated whilst CAM and PRO are active).
I've searched the forum but find nothing relevant.
Rick
RijK words all missing for arcline - SOLVED.
- Untitled.nc
- (544 Bytes) Downloaded 57 times
- circle test.dxf
- (121.42 KiB) Downloaded 50 times
Re: RijK words all missing for arcline
I can't see how to edit my original post but the Mach3 error code for the attached Gcode should read :-
RijK words all missing for arcline 12
Anybody?
Rick
Anybody?
Rick
Can you attach an NC file with arcs that works with your controller? Thanks.
Can you try to add a G01 before the G40?
If that works, the postprocessor can be adjusted easily as well.
N130 G01 G40 X16.1414
N210 G01 G40 X30.1421 Y0.8579
Andrew thanks.
Yes, the addition of the 2 G01 commands made it load and run in the Mach3 simulation window.
Another file attached that works.
Rick
Rick
- circle test.ngc
- (1.07 KiB) Downloaded 52 times
OK, thanks. This is a known requirement of the Mach3 controller.
Please use the "Mach3" configuration / postprocessor instead of the generic GCode configuration:
Andrew, thank you.
As I said in my OP I am trialling version 3.17.1 which does not contain the Mach3 post processor – (I did look at the post processing options before asking the question).
I note it has been added since and is available in V3.17.3.
As a hobbyist needing to count the cents I need to be sure it meets my needs. I find Qcad itself reasonably intuitive but want to make full use the Cam add on before buying.
Rick
Rick
