Entity from his center point
dzenita
Post by dzenita » Tue Nov 07, 2017 9:38 am
Hi everyone,
I am coding in a script, and I have to get the entity from it's center point.
Is it possible? Is there a function that gets entity from his center ?
Thanks,
Dzenita
Re: Entity from his center point
Post by andrew » Thu Nov 09, 2017 3:15 pm
You can query entities based on location using:
var ids = doc.queryIntersectedEntitiesXY(new RBox(x1,y1, x2,y2), true);
This will return all entities whose bounding box intersects with the given rectangle defined by corners x1,y1 and x2,y2.
If this does not solve your problem, please elaborate on what you are trying to do.
