[solved] Is there a better way to do this?
slyde
Post by slyde » Thu Dec 07, 2017 11:46 pm
Hi Forum:
I was wondering if there's a better way to use the dimension tool so that I don't get these extended lines.
Without dimensioning:
Screenshot from 2017-12-07 16-32-28.png (203.81 KiB) Viewed 2940 times
With dimensioning:
Screenshot from 2017-12-07 16-32-39.png (234.36 KiB) Viewed 2940 times
Screenshot from 2017-12-07 18-32-19.png (11.4 KiB) Viewed 2935 times
strange_lines.dxf
(109.42 KiB) Downloaded 337 times
Please advise. Thanks.
Slyde
OS: Linux M<int 18.3
QCAD Pro: 3.19.1.0
Look! It's a bird. No! It's a plane! NO! It's QCAD hotkeys...faster than a possum falling out of a tree!!
OS: Linux Mint 18.3 Sylvia [64-bit]
QCAD Pro 3.19.2.0 [64-bit]
Re: Is there a better way to do this?
Post by Husky » Fri Dec 08, 2017 4:48 am
slyde wrote:Hi Forum:
Not in the current version.
But you can fix that manually. Select the DIM and drag the Extension line back with help of the blue points ...
strange_lines_husky.dxf
(109.88 KiB) Downloaded 352 times
slyde
Post by slyde » Fri Dec 08, 2017 11:50 am
Thank you.
