I have been using a purchased copy of qcad for quite a number of years on Linux. Being a Linux user, not techie, I was so impressed with how good the software was I purchased a copy, not something I was used to doing being a Linux fan.
However things move on and I now have a Chomebook but can find no documentation anywhere on installing qcad, some simple instruction would be very appreciated.
I have Linux activated and have installed some flatpaks, but a Qcad install has left be baffled, not being a Linux techie even after 15 years, more a user me. I will be very pleased with this purchase once I have qcad running.
With Thanks
Springer
Install on a chrome book
Re: Install on a chrome book
I'm afraid that this will likely not work, at least not with QCAD Professional. There might be a QCAD Community Edition port available somewhere for Chromebooks.
Note that some Chromebooks use ARM processors. We haven't ported QCAD to that platform and the OpenDesign libraries (used for DXF/DWG support) don't exist for Linux on ARM processors at this point.
You could also try and install / compile Qt and the QCAD CE on your Chromebook but given your statement that you are not a "techie" that might not be a realistic option to pursue...
Springer
Thanks for the reply Andrew. Are you saying that there is a chance of an install from a tar package?
With Thanks
S
With Thanks
S
There's probably a small chance if it's an Intel-based Chromebook.
For ARM processors, you'd have to install Qt and compile the QCAD sources if that is at all an option for you.
Detailed installation instructions for running QCAD on ChromeOS / chromebook (Intel or ARM) using flatpak are now available on our website at:
https://qcad.org/en/qcad-installation-o ... chromebook
