SOLVED - trouble with block placement in v. 3.26
I have installed the new version of Qcad and now I'm having trouble with block placement. Some parts of the block are placed or duplicated outside the original coordinates, further and further away from the original position as you move away from the coordinates where the block was saved.
Has anyone had the same problem or can they give me a solution?
- Immagine 2021-03-05 164519.jpg (212.42 KiB) Viewed 6538 times
- Immagine 2021-03-05 164500.jpg (212.09 KiB) Viewed 6538 times
- Immagine 2021-03-05 164425.jpg (204.3 KiB) Viewed 6538 times
claudiaorch
Re: trouble with block placement in v. 3.26
Nope - works fine for me. Maybe you like to provide the dxf/dwg so that we can test it below the same condition.
This is a block file that when I put it in a new drawing as a block I have the problem. As a mirror! The problem is manifest on two Win 10 PCs.
- Dati-Dx.dwg
- (21.71 KiB) Downloaded 374 times
claudiaorch
Thanks for the file - I can reproduce the issue with the Polyline and Attributes.
Please file a bug report below https://www.qcad.org/bugtracker and I'm sure the developer will have a look at it. Thanks.
Win7 32 bit Qcad3.26
Can also reproduce this.
Known issue with polyline Widths
Here also Blocks and Widths, the 2R is reported as it also occurs outside Blocks.
https://qcad.org/rsforum/viewtopic.php?t=7889
Works flawless with 3.25.0!
I filed a bugreport:
https://www.qcad.org/bugtracker/index.p ... sk_id=2199
I use win10 S.O.
With the previous version there is no problem! Now I work with V. 3.25.2.0 without problems!
claudiaorch
The problem has also been fixed in QCAD 3.26.1.
