Due to the outstanding effort by forum member John Hyslop, I am now able to provide Linux DEB package installers and 64bit AppImages for Qcad Theme Designer and Qcad Theme Lite. The advantage of using DEB packages is that they will install in most Linux flavours. AppImages are executable files and will run by double clicking them.
Windows x32 installers are also included.
DEB (Linux) NOTES
- The launcher will be found in the Graphics menu section.
- If you already have QTD/QTL installed, these DEB versions will use the same configuration file as used by the previous versions.
Qcad Theme Designer update, version 5.1
Version 5.1 is a minor update, it introduces one addition, two changes and two bug fixes.
ADDITIONS
- A User folder button has been added to the browser, this will fully collapse the current tree and then open up at your User folder.
- browser.png (23.97 KiB) Viewed 2100938 times
CHANGES
- The Stylesheet Information and Shortcuts menu items that were in the Help menu have been moved to the View menu.
- The default stylesheet has been changed from monochrome to coloured.
FIXED BUGS
- Menu item Stylesheet>Open had to be selected twice to work.
- QTD now displays in dark themes correctly.
Qcad_Theme_Designer_v5.1-x86_64.deb downloaded 8 times
Qcad_Theme_Designer_v5.1-i386.deb downloaded 7 times
Qcad_Theme_Designer-x86_64.AppImage.zip downloaded 9 times
Qcad Theme Lite update, version 2.6
Version 2.6 is a minor update with just two additions, one change and one bug fix.
ADDITIONS
- A User folder button has been added to the browser, this will fully collapse the current tree and then open up at your User folder. (screen shot as above)
- If you associate .css stylesheet files with QTL, you can now open the stylesheet in QTL by right clicking on the file and selecting Qcad Theme Lite.
CHANGES
FIXED BUGS
Windows x32 Setup....
Qcad Theme Lite v2.6 Setup.zip
(2.86 MiB) Downloaded 455 times
Qcad_Theme_Lite_v2.6-x86_64.deb
(1.58 MiB) Downloaded 489 times
Qcad_Theme_Lite-x86_64.AppImage.zip
(3.18 MiB) Downloaded 476 times
Qcad_Theme_Lite_v2.6-i386.deb
(1.5 MiB) Downloaded 496 times
Qcad_Theme_Lite_v2.6-i386.AppImage.zip
(2.98 MiB) Downloaded 462 times
EDIT - x32 (i386) AppImage added.
