Selecting an object within a script
Shutterstock
Post by Shutterstock » Wed Jun 14, 2023 4:09 pm
I'm really new to QCAD and I am working on a script to discretize an arc.
I have the mathematical logic and it works on a non-interactive script, but I would like the user to be able to chose the arc they want when the interactive script is running.
And I don't know how to keeps the selecting mouse when running the script and what functions to use to grab the user selection.
Currently, my script looks like that (don't know if there are bugs inside, since I cannot test since I cannot select an arc):
include("scripts/EAction.js");
function DiscretizeArc(guiAction) {
    EAction.call(this, guiAction);
    this.nb_points = undefined;
    this.arc = undefined;
    this.setUiOptions("DiscretizeArc.ui");
DiscretizeArc.prototype = new EAction();
DiscretizeArc.prototype.beginEvent = function() {
    EAction.prototype.beginEvent.call(this);
    this.di = this.getDocumentInterface();
    this.di.setClickMode(RAction.PickArc);
DiscretizeArc.prototype.pickArc = function(event, entity, preview) {
    if (entity.getType() === 22) {
        this.arc = entity;
        if (preview) {
            this.updatePreview();
        else {
            this.applyOperation();
    else {
        EAction.handleUserMessage("Select an arc");
DiscretizeArc.prototype.getOperation = function(preview) {
    var doc = this.getDocument();
    var arcInfo = {
        centerX: this.arc.getCenter().x,
        centerY: this.arc.getCenter().y,
        startPointX: this.arc.getStartPoint().x,
        startPointY: this.arc.getStartPoint().y,
        startEndX: this.arc.getEndPoint().x,
        startEndY: this.arc.getEndPoint().y,
        radius: getRadius(),
        startAngle: getStartAngle(),
        angle: getAngleLenght()
    var arc_angle_n = arcInfo.angle/(nb_points-1);
    var line_entity;
    var op = new RAddObjectOperation();
    var x_temp = arcInfo.startPointX; var y_temp = arcInfo.startPointY;
    for (i=1; i<this.nb_points-1; i++) {
        var Dx = arcInfo.radius*cos(arcInfo.startAngle+arc_angle_n*i)+arcInfo.centerX;
        var Dy = arcInfo.radius*sin(arcInfo.startAngle+arc_angle_n*i)+arcInfo.centerY;
        line_entity = new RLineEntity(doc, new RLineData(x_temp, y_temp, Dx, Dy));
        op.addObject(line_entity);
        this.di.applyOperation(op);
        x_temp = Dx; y_temp = Dy;
    line_entity = new RLineEntity(doc, new RLineData(x_temp,y_temp, arcInfo.startEndX,arcInfo.startEndY));
    var id = this.arc.getId();
    var entity = doc.queryEntity(id);
    op = new RDeleteObjectsOperation();
    op.deleteObject(entity);
    return op;
DiscretizeArc.prototype.slotNumberOfPointsChanged = function(v) {
    this.number = v;
DiscretizeArc.init = function(basePath) {
    var action = new RGuiAction(qsTr("&DiscretizeArc"), RMainWindowQt.getMainWindow());
    action.setRequiresDocument(true);
    action.setScriptFile(basePath + "/DiscretizeArc.js");
    action.setGroupSortOrder(100000);
    action.setSortOrder(0);
    action.setWidgetNames(["ExamplesMenu"]);
Every help will be appreciated!
Re: Selecting an object within a script
Post by CVH » Wed Jun 14, 2023 7:58 pm
Hi, And welcome to the forum.
This question is more likely something for the 'QCAD Programming, Script Programming and Contributing' forum. :wink:
It seems that you want to turn one or more selected arc entities into line-segments. :wink:
Have a closer look at RArc.approximateWithLines() or RArc.approximateWithLinesTan() as that is already included in the standard resources:
Inside > https://qcad.org/doc/qcad/3.0/developer ... c896ef11a4
Outside > https://qcad.org/doc/qcad/3.0/developer ... 380ca1e3c2
You did not provide in the UI file: DiscretizeArc.ui
And the tool icon is missing too: DiscretizeArc.js
To use RArc.approximate... you need to get an RArc shape based on the arc entity:
var entity = document.queryEntity(id);
var arcShape = entity.castToShape();
Where document is a reference to the current drawing and id that of the selected arc.
One must filter on RArcEntity and can use Library.js functions:
https://github.com/qcad/qcad/blob/maste ... library.js See line 448.
For example with an array of selected item id's:
var idn = ids.length;
for (var i=0; i<idn; i++) {
    var id = selected[i];
    if (!isArcEntity) {
        continue;    // Ignore and skip to next
Where ids is an array of selected items and document is a reference to the current drawing.
Both RArc.approximate... return an RPolyline shape.
To return that to the drawing you need to construct an RPolylineEntity.
var newEntity = new RPolylineEntity(document, new RPolylineData(polylineShape));
Where document is a reference to the current drawing and polylineShape is the polyline shape you want to cast.
In the end we need to delete the arc and include the polyline, probably with the same attributes of the original:
var op = new RAddObjectsOperation();
... // Query selected, filter, modify ....
newEntity.setSelected(true);
newEntity.copyAttributesFrom(entity.data());
// Add new entity:
op.addObject(newEntity, false, true);
// Delete original entity:
... // All done >>>
// Apply all operations:
This code will return an array with the selected entities or all entities if none are selected:
var document = this.getDocument();
var ids;
if (document.hasSelection()) {
    ids = document.querySelectedEntities();
else {
    ids = document.queryAllEntities();
But you probably rather want to indicate each arc while the tool is running ...
The only thing missing then is an interactive script example with 1 state:
I think that Lengthen.js is a nice candidate:
https://github.com/qcad/qcad/blob/maste ... engthen.js
Of course you need to change Lengthen in DiscretizeArc to start with. :wink:
Post by CVH » Thu Jun 15, 2023 6:11 am
Shutterstock,
May I ask why you want to 'degrade' arcs to chains of line-segments .... ?
Shutterstock
Post by Shutterstock » Thu Jun 15, 2023 8:57 am
Sorry, I didn't know it exists
I probably miss something but when I try to "addArc(0,0,50,25,150,false).approximateWithLines(2)" in shell, it just prints me: "TypeError: Result of expression 'addArc(0,0,50,25,150,false).approximateWithLines' [undefined] is not a function."
The .ui file is basically the tuto file ExMyMinimal.ui, but I've replaced every "Radius" by "NumberOfPoints".
I don't know what is the tool icon sorry.
I'm stuck here, I don't understand what polylineShape is.
We receive high quality .dxf files, but when exporting, arcs don't simplify. The idea is to discretize the arc directly with QCAD.
Thanks for your help
Shutterstock
Post by Shutterstock » Thu Jun 15, 2023 8:59 am
Also, strange thing but when I try for example to do:
const Cx=1; const Cy=2; const R=200; const alpha=20; const beta=50;
var center = new RVector(Cx,Cy);
var di = this.getDocumentInterface();
var entity = new RArcEntity(document,  new RArcData(center, R, alpha, beta, false));
op.addObject(entity);
well, it prints me a circle:
Capture d’écran 2023-06-15 094939.png (8.55 KiB) Viewed 143733 times
but when I try to move a point:
Capture d’écran 2023-06-15 095430.png (76.47 KiB) Viewed 143733 times
now it transform it into an arc:
Capture d’écran 2023-06-15 095524.png (7.77 KiB) Viewed 143733 times
Post by andrew » Thu Jun 15, 2023 11:16 am
use ibb before the sequences, i can't post the link, the forum detects it as a spam
Please attach your images to the forum post instead of linking to them on an external site, thanks.
See:
https://www.qcad.org/rsforum/viewtopic.php?f=47&t=3760
Shutterstock
Post by Shutterstock » Thu Jun 15, 2023 11:31 am
See:
Thank you, I've edited
Post by CVH » Thu Jun 15, 2023 3:10 pm
AddArc is part of the simple API:
https://github.com/qcad/qcad/blob/maste ... _create.js
It would add an arc entity in direct to the current document at (0,0), radius 50, starting at 25°, ending at 150° being CCW.
One can use .approximateWithLines() with an RArc shape.
This should run in the Script Shell:
var arcEntity = addArc(0,0,50,25,150,false);  // Simple API
var arcShape = arcEntity.castToShape();
var arcPoly = arcShape.approximateWithLines(2);
var vertices = arcPoly.getVertices();
addPolyline(vertices);  // Simple API
deleteObject(arcEntity)  // Simple API
But that adds an arc entity, then modifies it to a polyline shape with line segments and then replaces the arc entity with an polyline entity.
It is not common to use the simple API in an interactive script.
Still to test your script we need a copy of the UI file as you are using it.
About the icon that is my bad ... A tool icon is initiated in the init section a would be called DiscretizeArc.svg
Both RArc.approximate... methods return an RPolyline what is a low level mathematical representation of a polyline.
This is not yet a drawing entity.
Sorry but an arc is the highest quality and the simplest form an arc can be.
One doesn't have to 'simplify' arcs ... Circles ... Ellipses ...
Replacing it with line segments decrease quality and makes it more complex.
Please elaborate 'exporting'. Exporting to or as what?
The simple API is in degrees for convenience.
Less simple ... The normal way ... Angles are in radians.
Shutterstock
Post by Shutterstock » Thu Jun 15, 2023 3:41 pm
OK I see
Here is everything:
In scripts>Mofidy>DiscretizeArc:
DiscretizeArcInit.js:
function init(basePath) {
    var action = new RGuiAction(qsTranslate("DiscretizeArc", "&DiscretizeArc"),
    action.setIcon(basePath + "/DiscretizeArc.svg");
    action.setDefaultShortcut(new QKeySequence("l,e"));
    action.setDefaultCommands(["DiscretizeArc", "discretizearc", "discretize", "dis"]);
    action.setGroupSortOrder(13200);
    action.setSortOrder(300);
    action.setWidgetNames(["ModifyMenu", "ModifyToolBar", "ModifyToolsPanel", "ModifyMatrixPanel"]);
current DiscretizeArc.js:
include("scripts/Modify/Modify.js");
 * \class DiscretizeArc
 * \brief Discretizes an arc by a number of points.
 * \ingroup ecma_modify
    Modify.call(this, guiAction);
    this.points = undefined;
    this.entity = undefined;
    this.pos = undefined;
DiscretizeArc.prototype = new Modify();
DiscretizeArc.State = {
    ChoosingEntity : 0
    Modify.prototype.beginEvent.call(this);
    this.setState(DiscretizeArc.State.ChoosingEntity);
DiscretizeArc.prototype.setState = function(state) {
    Modify.prototype.setState.call(this, state);
    this.getDocumentInterface().setClickMode(RAction.PickEntity);
    this.setCrosshairCursor();
    var appWin = RMainWindowQt.getMainWindow();
    switch (this.state) {
    case DiscretizeArc.State.ChoosingEntity:
        var tr = qsTr("Choose an arc");
        this.setLeftMouseTip(tr);
        this.setCommandPrompt(tr);
        break;
    this.setRightMouseTip(EAction.trCancel);
DiscretizeArc.prototype.escapeEvent = function() {
        EAction.prototype.escapeEvent.call(this);
        break;
DiscretizeArc.prototype.pickEntity = function(event, preview) {
    this.error = "";
    this.doc = this.getDocument();
    var entityId = this.getEntityId(event, preview);
    var entity = this.doc.queryEntity(entityId);
    var pos = event.getModelPosition();
    if (isNull(entity)) {
        return;
        if (!this.isSupportedEntity(entity)) {
            if (!preview) {
                this.warnUnsupportedEntity();
            break;
        if (!EAction.assertEditable(entity, preview)) {
            break;
        this.entity = entity;
        this.pos = pos;
        if (preview) {
        else {
            var op = this.getOperation(false);
            if (!isNull(op)) {
                if (this.error.length!==0) {
                    EAction.handleUserWarning(this.error);
        break;
DiscretizeArc.prototype.isSupportedEntity = function(entity) {
    return isArcEntity(entity) ||
           (RPolyline.hasProxy() && isPolylineEntity(entity));
DiscretizeArc.prototype.warnUnsupportedEntity = function() {
    //if (RPolyline.hasProxy()) {
    /*    */EAction.warnNotArc();
    // else {
    //     EAction.warnNotLineArc();
    if (isNull(this.pos) || isNull(this.entity) || !isNumber(this.points)) {
        return undefined;
    this.newEntity = DiscretizeArc.discretizeArc(this.entity, this.pos, this.points);
    if (!this.newEntity) {
        return undefined;
    return new RAddObjectOperation(this.newEntity, this.getToolTitle(), false);
DiscretizeArc.prototype.getHighlightedEntities = function() {
    var ret = [];
    if (isEntity(this.newEntity)) {
        ret.push(this.newEntity.getId());
    return ret;
DiscretizeArc.prototype.slotPointsChanged = function(points) {
    this.points = points;
 * Discretizes the given entity by the given number of points.
 * \param entity Entity to discretize
 * \param position Position clicked by the user
 * \param points Number of points used to discretize the arc
DiscretizeArc.discretizeArc = function(entity, position, points) {
    //var di = this.getDocumentInterface(); -> stop because of this, trying to work with this.di
    //var document = this.getDocument(); -> stop because of this, trying to work with this.doc
    polylineShape = arcShape.approximateWithLines(10);
    EAction.handleUserMessage("working 1");
    var newEntity = new RPolylineEntity(this.doc, new RPolylineData(polylineShape));
    EAction.handleUserMessage("working 2");
    EAction.handleUserMessage("working 3");
    EAction.handleUserMessage("working 4");
    // Add new entity: (in getOperation)
    EAction.handleUserMessage("working 5");
    EAction.handleUserMessage("working 6");
    return newEntity;
DiscretizeArc.ui:
<?xml version="1.0" encoding="UTF-8"?>
<ui version="4.0">
 <class>DiscretizeArc</class>
 <widget class="QWidget" name="DiscretizeArc">
  <property name="geometry">
   <rect>
    <x>0</x>
    <y>0</y>
    <width>177</width>
    <height>46</height>
   </rect>
  </property>
  <layout class="QHBoxLayout">
   <item>
    <widget class="QLabel" name="PointsLabel">
     <property name="text">
      <string>Points:</string>
     </property>
     <property name="buddy">
      <cstring>Points</cstring>
     </property>
    </widget>
   </item>
   <item>
    <widget class="RMathLineEdit" name="Points">
     <property name="toolTip">
      <string>Number of points to use for discretization</string>
     </property>
      <string notr="true">10</string>
     </property>
    </widget>
   </item>
  </layout>
 </widget>
 <customwidgets>
  <customwidget>
   <class>RMathLineEdit</class>
   <extends>QLineEdit</extends>
   <header>RMathLineEdit.h</header>
  </customwidget>
 </customwidgets>
 <resources/>
 <connections/>
</ui>
DiscretizeArc.svg:
<svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 512 512"><g transform="translate(0 492)"><g style="fill:none;stroke-linecap:square;stroke-width:16"><path d="m184-196l160-240" style="stroke:#000"/><path d="m184-196-96,144" style="stroke:#f00"/></g><path d="m355.79-288.46l26.709 17.625-70.5 106.84 26.709 17.625-92.94 53.689 12.812-106.56 26.709 17.625z" style="fill:#fff;stroke:#00f;color:#000;stroke-width:10"/><path d="m456.14-195.86l-28.877 38.859 30.375 40.998h-15.472l-23.24-31.373-23.24 31.373h-15.472l31.02-41.783-28.378-38.08h15.472l21.18 28.449 21.18-28.449h15.472"/></g></svg>
DiscretizeArc.pro:
NAME = $${TARGET}
SOURCES = $${TARGET}.js $${TARGET}Init.js
FORMS = $${TARGET}.ui
DiscretizeArc-inverse.svg:
<svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 512 512"><g transform="translate(0 492)"><g fill="none" stroke-linecap="square" stroke-width="16"><path d="m184-196l160-240" stroke="#fff"/><path d="m184-196-96,144" stroke="#f00"/></g><g fill="#fff"><path d="m355.79-288.46l26.709 17.625-70.5 106.84 26.709 17.625-92.94 53.689 12.812-106.56 26.709 17.625z" stroke="#0cf" color="#000" stroke-width="10"/><path d="m456.14-195.86l-28.877 38.859 30.375 40.998h-15.472l-23.24-31.373-23.24 31.373h-15.472l31.02-41.783-28.378-38.08h15.472l21.18 28.449 21.18-28.449h15.472"/></g></g></svg>
We then store the .dxf and reuse it later into Blender. And Blender likes points.
As you can see, the Lengthen.js file really helped me, but I'm stuck at "EAction.handleUserMessage("working 1");" while running the script.
I cannot also run:
but I don't know why.
I have also touched some things in advance like with "this.newEntity" in getOperation or getHighlightedEntities and I still don't know if it's correct or if it will make this not working lol
Post by CVH » Thu Jun 15, 2023 5:40 pm
Meaning Blender can't handle arcs? :shock: Is that for sure? :roll: :!: :?: OK, noted :lol:
I cannot also run:
It is DiscretizeArc.discretizeArc and not DiscretizeArc.prototype.discretizeArc so this has another meaning there.
Lengthen.prototype.getOperation sends this.Entity (by reference) and Lengthen.lengthen alters that entity in direct.
Lengthen.lengthen returns true or false (success/failed).
DiscretizeArc.discretizeArc should be a function that changes an RArcEntity into an RArc shape ...
... and further in an RPolyline shape given the parameters it receives.
getOperation should handle the entity conversion and return an operation.
There is a fundamental difference between:
RArc shape: https://qcad.org/doc/qcad/3.0/developer ... r_arc.html
RArc data: https://qcad.org/doc/qcad/3.0/developer ... _data.html
and an RArcEntity: https://qcad.org/doc/qcad/3.0/developer ... ntity.html
Question: do you need the clicked point for something? ... I think this.pos is obsolete for you. :wink:
Please declare your variables with var, they should all start in lower case.
Remind that with this script you have to indicate each and every arc entity in the drawing ... Is that the goal?
Ifso I would rewrite getOperation:
    // Fail without an arc entity:
    if (isNull(this.entity) || !isArcEntity(this.entity)) {
        return undefined;
    // Approximate arc and validate return:
    var poly = DiscretizeArc.discretizeArc(this.entity, this.points);
    if (!isPolylineShape(poly)) {
        return undefined;
    // Create document entity:
    var newEntity = new RPolylineEntity(this.getDocument(), new RPolylineData(poly));
    // Return operation:
    return new RAddObjectOperation(newEntity, this.getToolTitle(), false);
And rewrite DiscretizeArc.discretizeArc:
 * \return The arc approximated at the inside with a polyline with line-segments
DiscretizeArc.discretizeArc = function(entity, points) {
    // Avoid negative number of points:
    points = Math.abs(points);
    // Avoid no number or division by zero:
    if (!isNumber(points) || points < 2) {
        return undefined;
    // Cast entity to shape:
    // Determine segment length:
    var length = arcShape.getlength();
    var segmentLength = length / (points - 1);
    // Return approximate shape by segment length if possible:
    if (isNumber(segmentLength) && segmentLength > RS.PointTolerance) {
        return arcShape.approximateWithLines(segmentLength);
    else {
        return undefined;
Some further tweaking may be required. :wink:
    this.points = parseInt(points, 10);
Post by CVH » Thu Jun 15, 2023 6:09 pm
You could eliminate DiscretizeArc.prototype.isSupportedEntity() and .warnUnsupportedEntity() all togheter.
You have but one entity type and no relative choices to make.
Then rewrite:
            if (!preview) {
            break;
To this:
        if (!isArcEntity(entity)) {
            if (!preview) {
            break;
DiscretizeArc.prototype.getHighlightedEntities() seems fine to me.
Post by CVH » Sat Jun 17, 2023 6:40 am
Shutterstock,
First ... The shortcut LE is in conflict with Lengthen / Shorten (LE).
The tool icon is also identical to that of Lengthen / Shorten.
The code needed some further tweaking ... Fix typos :wink:
This is fully functional over here:
    ChoosingEntity : 0
        break;
        break;
    var entity = this.getDocument().queryEntity(entityId);
        return;
            if (!preview) {
            break;
            break;
        if (preview) {
        else {
            if (!isNull(op)) {
                this.getDocumentInterface().applyOperation(op);
        break;
        return undefined;
        return undefined;
    newEntity.copyAttributesFrom(this.entity.data());
    // Create operation:
    op.setText(this.getToolTitle())
    // Add entity and return operation:
    return op;
    var ret = [];
    return ret;
        return undefined;
    var length = arcShape.getLength();
    else {
        return undefined;
For some reason the polylines have 1 extra duplicated node at the end. :o :(
Probably the sum of things doesn't exactly match with the arc endangle ... = polar based.
Maybe this doesn't occur when we approximate the arc angle based .... Untested.
Refer to the resource signature:
The arc length in radians (isNot Sweep):
https://qcad.org/doc/qcad/3.0/developer ... e847e643ba
Still I think it is not a good idea to chop up an arc based on the number of segments ... A segment length would be more appropriate.
Post by CVH » Sat Jun 17, 2023 8:28 am
Tested and the results vary. :roll:
Solved by checking and removing/replacing the last vertex:
        return undefined;
    var length = arcShape.getLength();    // By arc length
//  var length = arcShape.getAngleLength();    // By arc angle
        var poly = arcShape.approximateWithLines(segmentLength);    // By arc length
//      var poly = arcShape.approximateWithLines(0.0, segmentLength);    // By arc angle
        // # Issue Fixed # Last vertex may be duplicate
        // Optionally we could remove the former last vertex if it is certain that the last vertex is equal to the arc endpoint
        // Fixed with:
        // - Removing last vertex when the last segment length is less than 1% of the required length
        // - Setting the new last vertex equal to the arc endpoint
        if (poly.getLastSegment().getLength() < segmentLength / 100) {
            poly.removeLastVertex();
            poly.setVertexAt(poly.countVertices() - 1, arcShape.getEndPoint())
        return poly;
    else {
        return undefined;
Shutterstock
Post by Shutterstock » Mon Jun 19, 2023 8:44 am
Sorry, I was in weekend :wink:
Thanks for what you did
Yeah, for example, here is the very first basic circle mesh you can add on Blender.
Capture d’écran 2023-06-19 083900.png (128.33 KiB) Viewed 143430 times
Ok, I think I see what you mean
Yes, because each arc won't have the same importance, so the user has to chose how they want to discretize for each arc
Capture d’écran 2023-06-19 093036.png (7.98 KiB) Viewed 143430 times
Where do you the a duplicated node? Can you give me what you are testing so I can reproduce?
Each arc don't hold the same importance, so simply discretizing all arcs by the same length is not optimal. And chosing a length instead of a number of points is less intuitive for the user
Overall, thank you so much for your time and your help!
I think I can also try now to let the user select a list of arcs, and then click on a "Done" button with a chosen number of points. It will discretize the list of arcs simultaneously.
Something that can also be added is a highlight of present arcs (so the user doesn't miss one)
I don't think that the highlight will make a big change to the logic of the code, but the list of arc might, since we won't work on hoovering.
Shutterstock
Post by Shutterstock » Mon Jun 19, 2023 2:22 pm
Kinda investigate, I think the only way to highlight the present arcs is to add them to a new layer, with different properties than the current one.
Something like:
// Create layer to highlight arcs
var arcLayer = new RLayer(this.getDocument(), "Arcs", color = new RColor("red"), lineweight = RLineweight.Weight035);
// Store the arc layer
var op = new RModifyObjectsOperation();
op.addObject(arcLayer);
var arcLayerId = arcLayer.getId();
// Grab all entities
var entitiesIds = doc.queryAllEntities();
for (var i = 0; i < entitiesIds.length; i++) {
	var entityId = entitiesIds[i];
	var entity = doc.queryEntity(entityId);
	// Store arcs in the layer
	if (isArcEntity(entity)) {
        	entity.setLayerId(arcLayerId);
And I would need to put back the arcs in the current layer and delete the arc layer if the user stops the script:
	// Put back arcs in the current layer
        	entity.setLayerId(currentLayerId);
op.deleteObject(arcLayer);
tho i don't know how and where to properly call these two.
Still investigating for multiple selection examples
