can not get Display distance/angle to work
SteveRay
Post by SteveRay » Fri Jun 28, 2024 7:29 pm
nothing happens when I hit the F8 key or select from the view menu
Re: can not get Display distance/angle to work
Post by CVH » Sat Jun 29, 2024 1:50 am
The information near your cursor is only displayed when indicating positions.
Try it out with drawing a line from two points (LI).
Indicate a first point and hover away, you will see a preview of the line but wait with indicating a second point.
Keep on hovering and hit the F8 key a few times.
That toggles the displayed information between: Nothing - Relative Polar - Distance - Direction - Nothing - ... and so on :wink: .
SteveRay
Post by SteveRay » Mon Jul 01, 2024 12:46 pm
I am doing what you say, but nothing is displaying. It has worked in the past. I don't know which version as I do keep updating.
Post by CVH » Mon Jul 01, 2024 12:56 pm
See menu Help .. About
SteveRay
Post by SteveRay » Mon Jul 01, 2024 1:32 pm
I just discovered that is only works if you have a snap mode selected. Does nothing if snap free is selected.
Post by CVH » Mon Jul 01, 2024 1:38 pm
Should work just the same for any snap mode.
Tested it in 3.30 and I can confirm that it only displays when snapped.
This could be regarded as a bug.
Please feel free to file a bug report: https://qcad.org/bugtracker/
You need to have or register for a separate account there.
Post by CVH » Mon Sep 30, 2024 5:44 pm
Related bug report: FS#2581
