I see the snapshot (so the next release will) uses Qt6. Does it use fully wayland (on Linux of course) ?
Do you plan anything about it (better performance/compatibility etc) ?
Keep the work !
QCAD Snapshot 3.31.2.4
Re: QCAD Snapshot 3.31.2.4
No, only the snapshots are using Qt 6.
Releases use Qt 5 on all platforms except macOS on ARM64.
You can use Wayland if you want but XCB is default. Feel free to download a snapshot release and try it on Wayland. Simply change -platform xcb to -platform wayland in the qcad launch script.
No, Qt 6 does not affect the performance or compatibility of QCAD.
