Bulk Trim?
Troy96
Bulk Trim?
Post by Troy96 » Fri Apr 11, 2025 2:49 pm
Is there a feature in QCAD that can 'bulk' trim lines similar to the trim feature in VCarve Pro? See below:
Bulk Line Trimming.gif (169 KiB) Viewed 11367 times
As you can see, this saves a lot of time in trimming lines like this.
Any input as appreciated!
QCAD Professional 3.31.2.0 on Windows 11
-Adrian
Re: Bulk Trim?
Post by andrew » Fri Apr 11, 2025 3:04 pm
You can use Modify > Break out Segment with the Line Selection Mode to trim away all the segments intersected by a line. The line is indicated by its start and end point.
Troy96
Re: Bulk Trim?
Post by Troy96 » Fri Apr 11, 2025 3:07 pm
Perfect! Thank you Andrew
