Issues with German Umlaute "öüäß" [solved]
Spititom
Post by Spititom » Mon Sep 16, 2013 8:23 am
I use 3.2.2.0 on a MAC running 10.8.5
I can insert Umlaute with the text tool, no issue so far. I then can pdf or print. But after save, close and re-open the Umlauts are replaced with other weird signs.
I used "standard" for texting.
Any ideas? It is not very convenient to go through the drawing each time before printing to insert the Umlauts.
Best regards,
Thomas
Re: Issues with German Umlaute "öüäß"
Post by andrew » Mon Sep 16, 2013 9:22 am
Thanks for your report.
This is likely related to or identical with this bug report:
http://www.qcad.org/bugtracker/index.ph ... ask_id=911
This issue has been fixed for the next release.
Spititom
Post by Spititom » Mon Sep 16, 2013 10:42 am
Thanks, looking forward!
Thomas
Post by andrew » Wed Sep 18, 2013 10:16 am
This should be fixed in QCAD 3.3 which is now available for download.
Spititom
Post by Spititom » Fri Sep 20, 2013 5:53 pm
yep. Gone is the issue. Thanks so much!
Thomas
