Possible New User: Question About Menus/Icons
Re: Possible New User: Question About Menus/Icons
Post by CVH » Fri Nov 17, 2023 7:18 am
Hi, John
John Hyslop wrote:
Fri Nov 17, 2023 6:54 am
The two buttons are "Make All White Layers Black" & Make All Black Layers White"
These methods are from the Misc section and have no associated icon.
The (Pro) scripts are named:
LayerBlackToWhite.js
LayerWhiteToBlack.js
Following Andrew's notes you then need to include under the Themes folder an 'icons' folder with:
LayerBlackToWhite.svg
LayerWhiteToBlack.svg
Unsure if this works because the initialization of these scripts don't call for an icon.
Let us know. :wink:
I think that for the QCAD Dark Theme you also need to include:
LayerBlackToWhite-inverse.svg
LayerWhiteToBlack-inverse.svg
-> With an identical look of course :lol: :P :wink:
Related Topic: https://www.qcad.org/rsforum/viewtopic. ... 41&p=37075
Post by John Hyslop » Fri Nov 17, 2023 7:44 am
Hi CVH
Thanks for the reply, it didn't work though :(
Also I'm not using a dark theme so I didn't saveas the other name..
I'll upload the svg's if yourself or anyone else could try..
(851 Bytes) Downloaded 1215 times
(851 Bytes) Downloaded 1264 times
Post by CVH » Fri Nov 17, 2023 8:06 am
One of the problems I am facing is that there is no 'Default' Theme listed under themes ....
Another is that there is no icon associated initially .... Remark that these are snippets from proprietary code
Not that there are big secrets in there ... Kinda common practice for addons :wink:
LayerWhiteToBlack.init = function(basePath) {
    var action = new RGuiAction(qsTr("Make all White Layers Black"), RMainWindowQt.getMainWindow());
    action.setRequiresDocument(true);
    action.setScriptFile(basePath + "/LayerWhiteToBlack.js");
    action.setGroupSortOrder(78100);
    action.setSortOrder(200);
    action.setWidgetNames(["MiscLayerMenu", "MiscLayerToolBar", "MiscLayerToolsPanel"]);
LayerBlackToWhite.init = function(basePath) {
    var action = new RGuiAction(qsTr("Make all Black Layers White"), RMainWindowQt.getMainWindow());
    action.setScriptFile(basePath + "/LayerBlackToWhite.js");
    action.setSortOrder(300);
Missing in both: action.setIcon(basePath + "/abcxyz.svg"); with the appropriate svg filename.
And then there is probably nothing to supersede ...
Post by John Hyslop » Fri Nov 17, 2023 8:15 am
OK
Thanks for confirming.. :)
Post by CVH » Fri Nov 17, 2023 9:12 am
John,
I was able to force at least one of your icons with a little script using the Script Shell :wink:
The other is basically a textual swap or simply iterate further until both are found and updated.
var actions = RGuiAction.getActions();
for (var c=0; c<actions.length; ++c) {
    var a = actions[c];
    var className = a.getScriptClass();
    if (className.startsWith("LayerBlackToWhite")) {
        a.setIcon("C:/Program Files/QCAD/themes/Default/icons/LayerBlackToWhite.svg");
        break;
Confirming what I wrote earlier:
CVH wrote:
Tue Nov 14, 2023 8:24 am
Maybe it is possible to alter all parameters for all RGuiAction's.
First hurdle would be a list of things. :|
In this way they only last for the current session of course. :(
