one of our customers cannot correctly see a DXF that we have exported from our commercial software. In this file there are many MLeaders that work perfectly with AutoCAD, ZwCAD,... but with QCad they are ignored.
I saw here https://qcad.org/rsforum/viewtopic.php? ... der#p19261 that they should be converted to Leader, and that's fine, but they are not visible.
You should see as this
But with Windows 11, on QCAD Professional 3.28.1.0 we can only see this
Albano
MLeader problem
- Registered Member
MLeader problem
- Piano terra.dxf
- (878.72 KiB) Downloaded 433 times
Re: MLeader problem
Thanks for your report.
I've created a bug report at:
https://www.qcad.org/bugtracker/index.p ... sk_id=2483
