How do I snap a line to another line with a specific distance?
ChrisCAD
Post by ChrisCAD » Sat Feb 17, 2024 7:03 pm
I'm trying to figure out how to snap a line to another line with the line set to a specific length, in my case 1.750". I have attached the .dxf file I'm working on. The 1.750" line I'm trying to accomplish will start at the end of one line and snap to the top line as seen in my screenshot below.
QCAD HELP.png (12.1 KiB) Viewed 6934 times
Line Snap.dxf
(95.92 KiB) Downloaded 515 times
Re: How do I snap a line to another line with a specific distance?
Post by CVH » Sun Feb 18, 2024 1:49 am
Please see snapping at a distance:
https://www.ribbonsoft.com/doc/qcad/lat ... ce_en.html
But what you need here is an auxiliary circle with radius 1.750".
Center at "End of this Line".
The required point is where the circle intersects the "Top" line.
ChrisCAD
Post by ChrisCAD » Mon Feb 19, 2024 2:11 am
Is it possible for you to explain in detail what you mean by "auxiliary circle"?
Post by Husky » Mon Feb 19, 2024 3:23 am
You don't need a manual construction with an auxiliary circle. Follow the "Usage" steps in the tool description and you get what you are looking for.
Post by CVH » Mon Feb 19, 2024 5:26 am
Husky,
Snapping at a Distance (SD) is in relation to endpoints of an existent entity.
The red line does not yet exist.
A future intersection point of a non-existent line piece 1.75 long is not a snapping point.
ChrisCAD:
Line Snap V2.dxf
Solution with auxiliary circle
(96.92 KiB) Downloaded 476 times
Construct an auxiliary circle R=1.75 with the center at the lower left endpoint of the green entity.
All points at a distance 1.75 are on this (blue) circle.
At two positions the circle intersects with the top green line.
These two intersection points are exactly at a distance of 1.75 from the start point of the red line to construct.
Now it is simply the question of drawing the red line from 2 points, from the start point to the rightmost intersection.
One can delete the auxiliary circle afterwards.
ChrisCAD
Post by ChrisCAD » Mon Feb 19, 2024 9:35 pm
Perfect! Thank you so much CVH!
