[SOLVED] Dimension units does not match drawing preferences
dale76
Post by dale76 » Wed Jun 19, 2024 2:19 am
Hi, new to QCAD software. Just started using QCAD version 3.30.1 on windows 10 pc. I have set drawing dimensions settings to Architectural units on both Application and Drawing Preferences with 0' 0" units. However, all of my dimensions appear as 0' 0; units. I have change settings and reapply them, but they continue to show the incorrect inch symbol. The inch symbol always appears as ; instead of ". A screenshot is attached below. Any suggestions how to correct this issue? Thank you.
Screenshot (6).png (246.43 KiB) Viewed 9125 times
Re: Dimension units does not match drawing preferences
Post by Husky » Wed Jun 19, 2024 2:52 am
your Label font is "RomanP" which most likely has a Simicolon [;] instead of a Quote ["] symbol.
Change the Label font to Standard, Arial or what ever provides the correct set of symbols and test it again.
Post by CVH » Wed Jun 19, 2024 5:52 am
The glyph's for 0x0022 and 0x003b are indeed identical.
Nice catch. :wink:
https://qcad.org/bugtracker/index.php?d ... sk_id=2577
dale76
Post by dale76 » Wed Jun 19, 2024 10:43 am
I changed the font to Standard and the dimensions work correctly.
Thank you for your help!
