PDF Conversion
fchaoyang
PDF Conversion
Hello. According to the responses from others in the forum, I have converted the dwg file into pdf file, but the fonts inside are garbled and the thickness of the lines are different after converting to pdf. I hope you can help me
- 3.png (88.1 KiB) Viewed 48591 times
- 2.png (85.94 KiB) Viewed 48591 times
- 1.png (179.36 KiB) Viewed 48591 times
Re: PDF Conversion
Please attach the source drawing file.
Your attachments are merely images, probably screenshots.
With a document in DXF or DWG we can investigate the output.
If considered proprietary then you could attach the drawing file(s) to a Private Message (PM) to one of the moderators.
Or to me if that would suite you.
The easiest way is to click on a user name and take it from there.
Your file(s) will then be treated in full confidentiality.
Re: PDF Conversion
You can set the maximum lineweight using -max-lineweight.
Please refer to our web site for dwg2pdf tool options:
https://qcad.org/en/qcad-command-line-tools#dwg2pdf
