ive opened a file that my coworker has worked on in Autocad. and the dimensions are huge. how can I adjust their size. my old dimensions- which were on the drawing previously, are a good size .
Im using QCAD pro 3.27.1.0
Dimensions are too large when i open a file
- Registered Member
- Screenshot 2024-07-04 at 11.18.08.png (69.37 KiB) Viewed 41276 times
Re: Dimensions are too large when i open a file
If not all dimensions use the same size, some of them might have style overrides. These are custom, per dimension entity settings for the label size, arrow size, etc.
You can reset all style overrides as follows:
Select > Select All
Dimension > Remove Style Overrides
After that, you can adjust the sizes for all dimensions in the drawing under:
Edit > Drawing Preferences > Dimension > Dimension Settings
Select > Select All
