H im using a 64bit asus chrombook plus and debian 12.
The process for getting an executable of the trial QCAD is/was extremely technical and tedious. Hwever with lots of assistance i now have a version that i launch from penguin with the command qcad.sh.
There is no way, without more help, that i can find andvdetete the pro files to convert to a long term free version.
Im happy to buy the pro version, but am daunted by the possibility of having to go through that whole process for the new download, andvas i read it for each update.
Is my assumption correct or is the purchased package, and future updates, easily executable?
QCAD is linux based, as far as i know, all the extra work was carried out within linux not chrome, so why is it made so difficult.
I have previously downloaded librecad with no probs.
Linux/Chromebook download
Re: Linux/Chromebook download
Installing QCAD should be as easy as download, make executable and run (based on the installer) or extract and run (based on the tar.gz).
See also:
https://qcad.org/en/documentation/installation
Perhaps, you can shed a bit more light on why you found the installation difficult?
See also:
Detailed installation instructions for running QCAD on ChromeOS / chromebook using flatpak are now available on our website at:
https://qcad.org/en/qcad-installation-o ... chromebook
