[solved] Ubuntu 24.04 Upgrade issues - QCAD 3.31.2 Pro linux-qt5.14-x86_64
IanH
Post by IanH » Fri Dec 13, 2024 12:16 pm
Hi Andrew,
I ran into some difficulties when upgrading from Ubuntu 22.04 to 22.04 - will not bore you with the details.
I had to install a new graphics card to work with 24.04 to get a suitable NVIDIA driver - now GT 1050.
I had to re-install all software and now have a working system with the exception of QCAD. I have recently renewed my license to QCAD Pro and have had another attempt to install this morning. I have followed the installation procedure and all seems well but the QCAD icon does not appear to work.
I have tried running from the installation directory directly using ./qcad but have had no joy.
The PC is dual boot and the windows 10 installation of QCAD works well.
Is this enough information for you to go on?
Ian
Re: Ubuntu 24.04 Upgrade issues
Post by andrew » Fri Dec 13, 2024 12:18 pm
Thanks for your report.
When running from the command line, what exact error message do you get?
What is the file name of the package you have downloaded and installed?
Thanks.
IanH
Re: Ubuntu 24.04 Upgrade issues - QCAD 3.31.2 Pro linux-qt5.14-x86_64
Post by IanH » Fri Dec 13, 2024 12:21 pm
Blimey that was quick!
Error message is
QCAD version 3.31.2
11:20:10: Info: Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
Warning: Application already running. Aborting...
Ian
Post by andrew » Fri Dec 13, 2024 12:27 pm
We first need to get rid of that with:
killall -9 qcad
killall -9 qcad-bin
Then try again and post again the error message. Thanks.
IanH
Post by IanH » Fri Dec 13, 2024 12:35 pm
Thanks!
All good now - many thanks Andrew, brilliant!
Ian
